1 - 9 of 9 Posts
hi, any of you knows where i could get one of those ? mine looks, hmmm....kinda broken or homemade. this is for jiffy reefing not the original roller kind. thank you
More important than the boat brand is the rig maker and the mast and boom section size and shape... pictures will help a lot.
Barquito
I have been thinking about replacing my gooseneck too. However, I am looking to get a fixed gooseneck. I worry that after I add a boom vang, the lateral forces on a sliding gooseneck will not be healthy.
The best place to get a gooseneck is actually with the original supplier of the mast and boom. Typically there is a sticker or engraving somewhere near the base of the mast, or at the deck that will have the mast maker and hopefully the extrusion profile. A quick call to the supplier is usually all it takes to get a replacement. For smaller extrusions these can run as little as $100, as they get bigger obviously the price goes up.
If you can't get an OEM part, they are not that difficult for a competent welding shop to fabricat. Figure 3-4 times the price of an OEM one going this route.
Discussion Starter · #6 ·
thank you Greg, i will check for the said label or engraving !
Barquito, would that be a gooseneck mounted on the mast ? please let me know if and or where you find one !
Barquito
I couldn't find anything that identified my boom. I will probably just go with what I have now. My other thought was that it might be possible to find a whole boom from a boat someone is parting out. You would need to get the fitting off the mast too. Wouldn't need to be from a B27, just at least as long.
You will find a replacement gooseneck at rigrite.com they carry most of the fittings on first gen Bristol spars.
Good luck,
David
1 - 9 of 9 Posts
