Bulkhead Beam under Mast Replacement
2K views 2 replies 2 participants last post by  TanzerChris
#1 ·
Hi All,
Big week just bought my first boat a 1975 Tanzer 22 - and new to the forum.
I wanted something inexpensive, I could spend a few seasons on and get used to: a) sailing and b) repairs and maintenance.
The first big project to tackle, is ensure everything is structurally sound.
When I did my initial walk around I saw no major cracking in the deck and the "knock test" up top everything sounds nice and solid - Although the mast step looks a little compressed - possibly from super tight rigging.
Inside though things are a little different.
The cabin ceiling is a little saggy (under the hatch), and there is evidence of water penetrating (stains) at the chain plates.
I want to remove the mast, get the bulk heads out and cut away the interior to have a look at the inside of the structure.
Has anyone here gone through this process?
Does anyone know if there are good aftermarket fabricators of structural parts for Tanzer22's?
I want to have a restoration game plan (worst case scenario) is I need to do some repairs.
Im super handy (carpentry/welding/fiberglass et al), confident with most projects I just need a game plan.
Any insight would be appreciated.
Thanks in advance
/c
#2 ·
Replaced bulkheads and chainplates on my North Star 26 this summer. I had a similar problem with the mast step depression, and leaking at the chainplates wrecked the old bulkheads. It was a very educational process, also hot, dirty, and generally unpleasant but at the end of it all, the boat is stronger than new.
I don't think you are going to find aftermarket structural components. You will have to fabricate those. I remade my bulkheads with 3/4" hardwood ply from home depot. Covered them in fiberglass and epoxy.
The mast step depression is likely due to a stringer failure in the bilge. In my case the manufacturer used a fiberglass/plywood stringer to support the compression post. It was not waterproof and after 40 years, the plywood was all but gone and the mast sinking under the rig tension. I built a new, much heavier and waterproof stringer to take the load.
There are a lot of YouTube videos that cover bulkhead installation (fillet, tabbing, etc..).
If you post pictures of the problems you are dealing with, you'll get better feedback.
