41 - 56 of 56 Posts
I'm in the process of building a LPG locker that will hold two composite LPG tanks. It will be mounted on the starboard side of the main hull under the stern rail seats, between the main hull and the ama. The locker is being made from 3mm marine plywood that is being laminated to 6mm and fiberglassed over.
As for doing the glasswork in the water vs. on the hard, there's a couple of things to consider. First, the marina might not let you do it on the water because what happens if goop spills in the drink? They're probably subject to environmental laws that prohibit such a risk. Secondly, if you're doing it in the water then the only place to stand is on the deck or on the float... either way not the most comfortable spot. If you're going to be hauling to deal with blisters or whatever, you might as well do the deck at the same time since both of them will require drying time.
A weekend might be pushing it for doing the hull. Doesn't give much drying time.
As for the Propane tank, we had(have) a very similar issue. Given the regulations, building it into the locker in a small boat is just so much hassle (airtight from cabin, vented outboard from the lowest point in the compartment). The stern locker is usually too small and the port/starboard lockers end up putting any possibility of an outboard vent below the waterline when heeled.
Your best bet is to hang the tank on a bracket off the stern beside the motor (this is what our surveyor suggested). Use a small tank (or even rig up a system with the little disposable bbq canisters). There is no point in trying to hang a larger tank as it would probably last you multiple seasons then for the amount of propane the range actually uses.
Discussion Starter · #44 · (Edited)
Success! The boat is ours, and safely moored in Reed Point Marina. Here's a link to some photos from her haul a while back:
It was certainly a bit of an adventure. We meant to leave Victoria Saturday afternoon, but it was blowing 35, gusting 45 in the Juan de Fuca straight. Seemed a bit foolhardy even for us. We installed a new battery, discovered all the lights were working (!) and installed a bilge pump. We were up at dawn on Sunday to run to Ganges, and then a tight run for Clam Bay just as it was getting dark. We were the only boat in the anchorage (and apart from racers, one of the very few boats even out.) We woke up Monday morning (after a freezing night in a tiny boat with no heating) to a sheet of ice on the deck, and 2 inches of snow, and less than a mile of visibility. The snow did help with insulating the boat though. ;)
(Don't mind the very sloppy bucket in the cockpit.) We chose to sit tight for the morning, and once the ice on deck had melted (somewhat) we ran for Degnan Bay, where we dropped the hook in the channel and did some necessary "improvements" - a jury-rigged cunningham/reefing line, replaced the line in the traveler and the vang, and cobbled together a reefing system, as we were expecting heavy winds on the crossing. Woke up to wind howling in the rigging and a change in the current. After debating whether we'd hold on the smooth rock bottom with our claw anchor, the boyfriend decided we'd be better off at the gov. dock for the remainder of the night. Ahh... nothing like finding out how your boat feels than hauling anchor in strong currents and gusting winds to dock your boat in the dark.
We passed through Gabriola pass at slack water into 2 metre swells and turned for Vancouver. We considered running the sails, but the decks were still covered with sheets of ice. Except now, with rollers hitting us abeam, and waves breaking over the foredeck, this was saltwater freezing on deck. Take a look at the icicles that formed on the "lifeline" (yes, replacing the lifelines is one of the first projects)
Here's me at the helm looking thrilled at the cold weather:
At least by that time the seas had settled some. We made it home safe and sound in the end, if a bit chilly. Oh, were we dreaming of the warm blue waters of the Caribbean.
The boat handles beautifully. She's nimble and handles even pretty big water with ease. There are a few odd things with the rigging (namely that the current ownder used goldbraid as the main halyard, and there's no winch. Which means I'm at the mast standing on a very ****** (icy?) deck pulling on a halyard which refuses to go up any further, as it simply stretches. *sigh* We can't seem to get the sail up high enough, leaving the boom with a rather severe downward angle.
In short, we're thrilled, even if we realize how much of a project boat she truly is going to be.
*Photos don't seem to be working. Here's a link to them on Flickr. Samurai Survey & Trip Home - a set on Flickr
Congratulations! Well done. Takes a hardy sort to deliver a boat in these conditions. It is uncommonly cold this week, I can see why you're bundled up. Last week I took my boat around to Mosq Cr for a haulout... could've used some gloves then and that was only an hour!
Now all you need to get is that slip closer to the action. Hope to see you out there one day!
Wow... so it's the Bering Sea for you next, I suppose. Incredible trip. Although it couldn't have been that cold -- your camera's batteries were still producing current :)
Got any pictures of the limping boom and main? Wonder what's going on there.
Anyway, congratulations on bringing her home safe and sound, and with repairs performed underway, no less. She sounds like she's in good hands.
Discussion Starter · #47 ·
Well, it wasn't that cold... apparently, it was only -14C with the wind chill yesterday.
And, she's remarkably non-drafty down below. Some decent hatch tape on the forward hatch (we took on some water as we plowed through a couple of the 2+ m waves) should fix that. Luckily, we'd anticipated that, and had a tarp down over our kit.
We'll be down tomorrow night again to start the other projects. If we can raise the main while at the dock, I'll snap a few and ask questions. I think part of it is that the main simply seems too big (it's from a Thunderbird). I'll take a tape measure and do IPJE and all the others sometime soon. Even with a loose outhaul (which currently doesn't work at all ;) ) there's not much space at the end of the boom to haul it out. The boom height is adjustable, which helped when we hoisted the second time. I hope most of it is that ridiculous halyard, and hence not enough tension in the roach/leech.
Congrats on the safe delivery Sarah! Good to see some more sailers that aren't scared of the chills.
We'll have to have a little 24 footer race in the arm ;) We'll definitely keep an eye out for Samurai... If the wind is blowing, there is always a good chance you'll see Troika the San Juan 24 out there keeping the bottom clean.
FYI: http://www.deepcoveyc.com/downloads/RaceSch08and09.xls They are keen to have more boats racing with them; we are going to jump into our first season this year!
Congrats Serah. Post photos when you can. :)
Nice pics!
Congrats on your new to you boat, looks very nice. I guess Indian Arm will be your practice grounds at Reed Point. I can't believe you got yourselves out there in the cold we have had this week, you must eat nails for breakfast to be that tough.
I couldn't help thinking about your stretched halyard dilema. This may not be your case but it happened to me in my first season. I had a similar problem in that I could not get the mainsail all the way up the mast. I thought something was hanging it up in the slugs or perhaps blockage in the mast track, but try as I did the stupid thing just would not go all the way up and the boom was hanging on a slant downwards. So I finally sat down right there at the mast base to ponder my situation and when my eyes glanced along the boom to the boom vang I saw the vang was pulled in real tight and holding the boom down thereby holding the leach of the mainsail tight. No wonder the stupid sail woulddn't go all the way up. So I loosened the vang and the mainsheet as well, then up went the mainsail all the way to the top. DoH, I was a beginner so I did not realize the problem immediately but I have since come across the odd newbie suffering the same experience as me and was able to point out the problem, after which they got a good laugh. It was probably too cold for you to sit out there to troubleshoot the situation but by now you may have already figured it out.
Enjoy your new to you boat, they are wonderful toys, and the $$spending never stops.:)
Discussion Starter · #51 ·
Well, we really didn't have a lot of choice - she had to be brought home soon, as the previous owner (Ahh! how nice to be able to say that instead of current owner!) needed his slip. It was either take her home in the cold (but fair winds) or leave her on transient moorage at easy 50$ a night and quickly eat through any savings we may have made on her. Plus, there's something to be said for pushing yourself - I wonder how much of a mental block it would have created if we'd told ourselves "no, we should wait. It's too rough/cold out today." That would linger in the back of our minds, likely making us hesitant to attempt another roughish crossing. It always amazes me how much of a drogue the "I can't do it" mindset can be...
If only our sail problem could be resolved so easily! The vang was loose, as were the main sheets and pseudo-cunningham. We were pointed dead into the wind, so it wasn't filled as we hoisted. We have the engine off for some much needed TLC (though she ran like a champ! A bit rough to start, but got us the ~70nm home without stalling or anything!) but we'll try to hoist this weekend and see what exactly is going on.
As for the other sails, I'm thrilled with the funny dual-track jib-hoist system (apart from her tendency to flap in the wind while on the hook, and her one jagged edge which tore a hole in my down vest :( ) I've never used one before. Apparently, the idea is to be able to drop one sail while hoisting the second. However, the tracks seem to be different sizes? A lot less work than hanking, and much quicker to boot.
I'm very interested in seeing how she compares to the San Juan 24'! That was one of the other boats we'd considered. Apparently, she was designed as a competitor (read: to be a touch faster!) than the San Juan. Give us a few months to coax her back to health, and for me to teach the boy (and admitedly, fully remind myself!) how to sail spin, and we'll challenge you to a Sailnet Battle of the Classes sail-off ;)
Hehe, reminds me of the other day when I got a good laugh at the Admiral after she had been frustrated by attempts to check the battery voltage at the motor, but had neglected to take the protective plastic tips off the multimeter first. She got a good laugh at me after I too was frustrated -- because I had neglected to switch on the batteries :)
We all miss the obvious now and then.
Did you say it was a sail of a Thunderbird? Best info I can find is that your "P" meas is 30 vs the Tbird's 31 (thats the length of the main along the mast, btw.)
If the sail hasn't been modified that could be your problem right there.
Get yourself a 50' tape measure and check it out....
Discussion Starter · #54 ·
I assume the sails are from a Thunderbird - I don't think they still have the T-bird insignia on the sail, but all the bags still have it on them. As I said above, it seems big for the space. However, with the adjustable boom height, perhaps we can make it fit. Is there any disadvantage to pulling the boom down lower? It looks like there's still about 10 inches to the top of the mast from the head of the sail when it's as snug as I can get it. I hope that will be enough to pull it up, but I'm starting to doubt that.
I've not been up the mast yet (we have a few masthead projects - wind indicator, refitting the halyard, possibly running a masthead light) so when I do I'll take some measurements. Actually, there's a question - how does one normally do masthead repairs/inspections on a 24' boat? I've only ever done them on a 42', when I just went up in a bosun's chair or climbing harness. Is it safe to go up on a boat this small, or would it be safer to simply drop the mast (*sigh*)?
Uh oh, looks like we might be in trouble as we don't have a kite to fly! and are sporting some tired sails :eek: And YOUR boat looks like a bullet!
Oh man, I have been plauged by this question as well! I have actually climbed half way up the mast using my climbing harness and slings (didn't get winched up a halyard) and that was enough of a struggle! I really don't want to drop the mast, but now it looks like our steaming light has finally packed it in :(
If you have any quick fixes, pending approval from the boss (girlfriend), the gf's suite balcony overhangs deep water that with the right jockeying and the right tide, is at masthead height (or at least the landlords above is at mid-tide when there is more water). I have also snuck onto the neighbours pier in the dark to replace the bulb in the steaming light :lol:
It's safe enough to go up on a chair... make sure the halyard looks up to the task. The biggest problem with little boats is finding enough winch power to haul someone up. Set up another halyard along the mast (preferably rope) so you can pull yourself up and help yourself along. It will be noticeably less stable than the 42 footer up there.
If your sailbags all have a Thunderbird insignia, they may well be from a former sailmaker by that name, rather than meant for a Thunderbird 26. They (Thunderbird sails) were around back in the day. I suspect that you probably have Thunderbird sails, rather than a sail for a Thunderbird..... if you get what I mean!
41 - 56 of 56 Posts
