1 - 20 of 37 Posts
Pictures of the rip out phase. Both quarter berths gone because the wood was rotted from leaking side lights. First longitudinal bulkhead supporting the counter top removed.
To Do:
Remove the forward most longitudinal bulkhead supporting the counter top.
Remove top of V-berth
Remove deck hardware and teak hand holds
Cut new V-berth
Cut new support bulkheads for the counter tops
Cut new sides for the swing-keel housing
Rework the cockpit to deck connection
Fiberglass weak areas where light comes through hull
Sand entire below decks
Paint below decks and add new fabric to replace original (ripped out a long time ago by a previous owner).
Rebed deck hardware
Prep hull and cabin top for painting.
About 2 weeks work, wouldn't you say? :laugher
Discussion Starter · #3 ·
Last longitudinal bulkhead that supports the counter top removed. V-berth top removed - looks like I'll take out the V-berth supports, also. Fiberglass dust everywhere like white talc. Need a better respirator and googles. Have a zip up tyek suit.
Discussion Starter · #4 ·
Any suggestions on painting the inside of the cabin and hull, and the outside bottom, cabin and hull?
It looks like it had fabric in the cabin and V-berth area at one time. I think I see remnants of the adhesive in those areas under paint.
Suggestions for fabric?
Ot, Wondering why you chose to start a new thread. I have a tough time keeping track of what's going on Cal21 wise. I am elderly. But I too am working on my Cal. Just installed a couple of reinforcing bulkheads on the port side of the trunk. Right side seems OK. Also ripped out all the ply on the sides of the qtr berths, and cut two 1/4" ply tops to install over the existing ones...after I replace the posts and rails that have collapsed(actually I don't think there were ever any posts in those spots). Lots of other jobs to work on, but none that will keep me from launching soon.
Discussion Starter · #6 ·
Rippy,
I didn't want to hijack someone else's thread. Have any pictures of your progress?
I removed the V-berth supports yesterday evening. Now I have to take off the deck hardware so I plug "extra" holes from previous owners and sand the entire below decks and hull in preparation for painting.
Do you have a headliner in your Cal? I am thinking about installing one.
I'm not saying how old I am but I was born in 1956. :)
Ot, No pics right now. My current goals are different than yours I think. I was born in '37 and my plan is to just use 21 as a daysailer. Only work inside was to firm up support around the trunk. Well I did have to remove a lot of peeled paint and rotted plywood. Never any sign of cloth on ceiling or anyplace else. Guess the point is that the interior is not my priority. I have only sailed the boat a couple of times and that was just before a hurricane washed it off it's mooring. Long story, won't go there. I have a big fear of losing the keel as described on the other forum just now. Other owners have placed that fear in my head. I didn't like the fact that the wire stayed attached to the keel when I did sail it so researched how to get that whole rig back to factory standards. Did find a lot of info, but haven't solved the problem yet. I also have no way to remove the keel to check the hole that the pivot bolt runs through without spending bucks, which I don't have a lot of. I need to do some work on the transom, the keel space in the cockpit, jib roller reefing, and you may have seen my posts about cutting off the bottom of the mast to reduce heeling and the need to sit on the hull all the time. Too old for that action. I have the boat sitting on it's trailer with the mast raised right now. I am evaluating a very simple roller reefing rig that came with the boat. Have not used it. I got the boat from a fellow who was not a sailor and who scared the hell out of his girl friend and probably soiled his pants. When "they" say the boat is tender, I am in complete agreement.
this is already too long. More later? Off to reply to the other poster, Ron Plasse. :)
Discussion Starter · #8 ·
I think I just uncovered more work to do.
I took the rub rail off and some of the screws holding the aluminium rub rail weren't biting into anything. May have to drill some out and plug. Actually, I should probably drill out and plug all the rub rail holes.
After removing the rub rail I noticed the stern deck seems to be lifting or not securely attached to the hull.
already decided to remove all the deck hardware, dill out an plug holes, then re-bed the hardware. Just waiting for a little help topside while I'm below decks to get this hardware off.
Then it will be patch and sand the imperfections in the hull and cabin.
Decided no headliner because I think it would retain moisture and grow mold and mildew.
I think my last estimate of splashing this Cal just extended into July.
Pictures later this week.
Discussion Starter · #9 ·
More pictures. I either made a hole in the hole or found one. I'm leaning toward I made it with the edge of a sanding wheel. Deck on the stern looks like it is coming apart along with some damage on the stbd corner that was covered by the rub rail.
Discussion Starter · #10 ·
Picture of the stbd side showing a light blue stripe under a black stripe. I like the original color.
Bow area of cabin with the V-berth removed and the inside hull mostly sanded.
Pictures of the port and stbd cabin deck showing raised fiberglass the was holding the rotted quarter berths. I have to sand those down, also.
Coming along slowly.
Discussion Starter · #11 ·
Re: CAL 21 Refit in South Carolina Deck is Off
Used a Harbor Freight Oscillating Tool with Rockwell scraper to separate the deck from the hull. I was wearing a white painters suit (from Northern Tool) because I had to crawl under the cockpit to remove the nuts from the rudder pins and outboard motor mount.
Discussion Starter · #12 ·
You can see the rotted wood on the transom. Looks like a patch work of pieces to support the rudder.
Both deck chain plate areas had been rotted and repaired before and need to be replaced, again.
You are quite the surgeon! And it looks like you got to your patient just in time. Was this boat sunken at some time? You have earned my hearty admiration for taking on this task. I reckon it will be a labor of love. Do you have a target date for launch? If you have pics of the keel I would like to see them.
Discussion Starter · #14 ·
As I am sanding off the interior white paint I find a tan color covering underneath it. The white sands off easily but the tan (paint?) takes more work to remove.
Anyone know what the tan covering is?
About 90% of the inside of the hull is sanded. Pictures soon.
Discussion Starter · #17 ·
Sanding the inside of the hull under the cabin is 99% finished.:) Just the tip of the bow left.
Built a frame to lift the hull but it is a work in progress. I need support closer to the hull to keep it from opening up when I work on that side.
Pictures show my progress.
Are you planning on using that frame to lift her off the trailer? I would caution you against that as right now the trailer is the only thing helping her hold her shape. (fiberglass is amazingly flexible) I would suggest putting the two major structural bulkheads in before taking the trailer away.
Discussion Starter · #19 ·
Eventually I want to lift it off the trailer and drop the swing keel.
But I still have work to do on shoring the hull so it won't go like rubber. You're right, fiberglass is very flexible by itself.
I finish the top of the inside of the bow sanding and then it's on to the deck and cabin.:D
Discussion Starter · #20 ·
Finally bought a 10' x 20' shelter to keep the rain out of the hull and the sun off me while I'm out there.
Before and after of the transom rotted wood removal.
Pictures of the stern from the outside.
Hull paint: The white is thick. Under the white the entire hull appears to be light blue. The blue seems pretty thick. Under the blue is a light coat of grey (primer?). Some previous owner painted the blue stripe black.
Bought a 3/4" 4' x 8' sheet of marine plywood to use for the bulkheads that go across the forward end of the swing keel housing.
Any suggestions on the type of paint to use on the inside?
1 - 20 of 37 Posts
