1 - 6 of 6 Posts
I am conducting a haul-out inspection on a 1980 Cal 31 next wednesday and would like to have on hand a prop shaft anode to install before boat is put back in the water. Does anyone know the shaft diameter? Boat is equipped with a Universal Atomic Diesel Model 5416.
Crawl in behind the engine and measure the shaft inside the boat... not likely to change from that.
Reactions: Cal31Windchaser
Discussion Starter · #5 ·
Thank you all. I should have measured the shaft, aft of the transmission, like "Faster" suggested. However, I am now in Tennessee and the boat is in Georgia. Will have to purchase the anode prior to getting back to the boat.
Learning the HARD way...
Save yourself a headache, and hedge your bet.
Before you go to the boat, stop by the local West Marine and buy two of each of the following:
  • 3/4" Zinc Annode
  • 7/8" Zinc Annode
  • 1" Zinc Annode
  • 1-1/8" Zinc Annode
Install two of whichever size is correct (99% sure it will be 1"). When through at the boat, stop by West marine and return the Zincs that you did not use.
1 - 6 of 6 Posts
