1 - 20 of 21 Posts
Discussion Starter #1
My new to new boat has these rope clutches that I assume are original to the boat (1985 Helms 32). I’ve never used clutches like these and they make me a little nervous. Can anyone identify them? I’d like to explore replacing with something that hopefully has a similar bolt pattern.
136455
Master Mariner
Yep. We have the same ones on Skipping Stone. They're Schaefer Marine. Work great, simple and functional.
Discussion Starter #3
Ok I'm glad to hear that. I'm just used to something that I can feel lock in place so I was a little iffy about them. I'll experiment with them a bit more. Thanks
Master Mariner
They have springs in them and in any position other than straight up, they'll stay down on the line allowing it to come in but not out. They may need lubing.
Reactions: mljohnson1
I also had them on my previous boat. One issue is that when locked and under load, you need to tension the line to be able to release it. Can't (usually) just push forward on the lever. Otherwise simple and work just fine.
Discussion Starter #6
I'm thinking I may need to check the springs in mine. I'm not at the boat now but when I was messing around with them yesterday they didn't seem to stay down on their own.
Thought the springs were non functioning on my new to me boat's Schaefer clutches. They still worked fine as long as pulled the lever down so they'd engage the line. Finally got the brilliant idea to break out the WD40 and low and behold now functioning spring locked clutches.
Master Mariner
Exactly!
We’ve got them too....37 years later still work fine
However replaced others with Garhauer ones. Industrial looking and worked great. No more tensioning the line to release them
Discussion Starter #10
Did the mounting holes match up with the Garhauer ones you installed?
No unfortunately
Barquito
I've got a few of those. Didn't even know they had springs. I think my springs have sprung. They are, indeed, difficult to release under pressure. This can be difficult single handed with non-tailing winches... when a storm is approaching... and your hat just fell overboard... etc.
We replaced ours because releasing them under load ended up with the handles getting bent and/or breaking off. (We had gorillas on the midship control-adjusting team who wouldn't wait to take load up on a winch.) Holes didn't line up, but we were able to make sure the new clutches were installed properly in our balsa-cored cabin top so they stopped leaking.
I have two on my boat, and I have to pull the lever down to get them to engage. I'll try the lube to see if it helps. Thanks.
If anyone needs a working two line clutch with good springs, I have one for sale. Replaced with a 5 line clutch and have already sold two, just this one left. Listed on eBay at $29 under sailing hardware. Make me an offer I can't refuse.
One of the first things I did on my last boat is replace the Schaeffer clutches. We called them "suicide clutches" because they were so difficult to release under load. Not to mention their spike-like handles sticking up waiting to impale someone!
You will never find anything with the same bolt pattern. You just have to fill the old holes and drill new. If you are lucky you may be able to cover some or all of the old holes with your new clutches.
I installed Spinlock XTS clutches, but if you don't mind the look of Garhauer they are pretty good for less money.
Sent from my SM-G960W using Tapatalk
Isn't Garhauer standard equipment on Catalinas?
Not sure what you mean by the “look” as they are completely Stainless steel
Heavy and solid construction
10 year warranty vs 5 for Spinlock and other clutches
Garhauer has a very industrial look and no soft edges. they seem to hurt more when you trip over them and no not standard on Catalinas. I have gone to Ronstan Constrictor clutches on my halyards no more worn line and they do not slip
Yes they look robust Stainless Steel construction . I’ve had them for 8 years have not chewed up my lines
practical Sailor also rates them very highly
you are dead wrong about Catalinas relationship with Garhauer. They heavily advertise their at Catalinas relationship
Garhauer is a truly customer service company and has well made stuff at usually more thrifty pricing than the competitors.
I have their 1.25 inch davits, radar pole and engine hoist, line stoppers turning blocks. Have thought about replacing my travel or with theirs. I saw that replacement on a SN members 37 Tartan and liked it
I have no affiliation with them
Don't take it personal! I just think they look a bit industrial for my taste that's all.
1 - 20 of 21 Posts
