1 - 20 of 20 Posts
first sailed january 2008
So I'm buying a boat and depending on how low I can get it for there is a Cape Horn windvane for sale that was installed but never used.
I've read good things about them, they look much easier than the aries/monitor style and lighter which is good for the 8-10000 lb. boat I'm going to get.
I've always wanted a windvane. I will also use a tiller pilot for motoring and light weather. What do you think the cost of installation would be or how much was it for those of you that did it? It's drilling the hole that I would have done. That and glassin the tube in place. Since nothing is below the waterline do you have to haulout? I assume so but what do I know, maybe it's easier than I picture.
Bristol 45.5 - AiniA
I know you are on a budget. I great thing to do is not ask how much it would cost to install, but what skills would I need to do the install myself. The skills you learn will prove invaluable to you at some later date when there is no yard around to do the work. Also you will save yourself a whack of money.
My only concern with buying the vane first is whether the boat you buy will take the Cape Horn. For example, on our boat we could not install a Cape Horn because of the configuration of everything inside the transom - we have no lazarette on the centreline and a bunch of things including a large structural knee and some very heavy duty plumbing hoses. Even installing a Monitor meant cutting a hole in the gas locker to get access to the inside of the transom on the starboard side.
Corsair 24
exactly what KS says...get the boat first man
there is also an aries, a sayes rig and a couple of monitors currently for sale in california...
windvane installation depends mostly on
transom design
rig design(think mizzen boom, or a boomkin etc)
RUDDER DESIGN
boat first then windvane
A buddy did on his Southern Cross 35. He did it himself. but you MUST have the boat first to be sure that it can be installed. He really likes his. It will even steer down wind in light air, something that is a real challenge for most wind vanes.
Discussion Starter · #6 ·
Oh boat first I know. I was just thinking. There are so many things that influence my decision on what boat to buy, like if it takes a windvane nicely that would be more reason to buy one. I just don't know how they are installed. What skills would I need? That is a better question. I've done some projects and the have for the most part went well, however I did have that one episode where I hired people to do something and it did not go well so I guess I will install myself. Good point.
Corsair 24
well most will require a drill, the need or not to make brackets, the need or not to bend or cut off tubing and then the need to rig lines if it uses them or not
for example some of the simplest to install are the sayes rig and a trim tab off the outboard ruddder
there was a thread not too long ago showing a capehorn being used on a boat not really best suited to a capehorn needlessly complicating a simple design
for example if you buy a boat with an outboard rudder you can install and or make a moitessier type trim tab vane or a murray vane or others...and save yourself thousands
if you have a lot of crap out back some vanes wont work as well...
if you have a very small boat an aries isnt the ideal vane as its big and bulky, the monitor although lighter has the reputation of looking like an oil rig on most transoms
etc
other windvanes to look at
norvane
sailomat
plastik
bouvann kit
mr vane
atlantic vanes made in argentina
etc
Discussion Starter · #9 ·
Oh, I thought they were pretty much standard. Two tubes and some blocks and lines. I thought the monitor and aries style were more custom because you had to fabricate the mount. I will check out those others. I would be willing to pay 3-3500 for a windvane installed. Too bad there aren't any boats with them already on.
As posted vane choice has to be matched to the boat, both size and transom configuration. I think a Monitor is ill suited to a lighter boat as it adds too much weight in the wrong location - that is why I sold the one I had when I bought a 27' boat.
In my opinion, after a lot of research and owner feedback, the Norvane is an excellent choice for a boat under 30' as it weighs about half that of a Monitor. It gets very good reviews.
James Baldwin (Atom Voyages - James and Mei) has installed a few on boats under 30' and thinks highly of it.
NORVANE Self-Steering Wind Vane. Stainless steel, servo-pendulum. Powerful, sturdy and reliable for sailboats 20' to 60'
It is also one of the least expensive quality wind vanes available.
Bluenoser
I have nothing but good things to say about the Cape Horn windvane...but, of course, that's what I chose for my boat. Skill set required to install a Cape Horn is "average home handy man" - i.e. able to accurately measure, use drills, jig saws, etc. It took me a weekend to install and I did it with the boat in the water. The most intimidating part is drilling the big hole in the transom. Cape Horns are 'custom-made' for the boat as the length of the servo oar and the height of the windvane mast will be fabricated to suit your installation.
Corsair 24
I sold my old islander 34 with a an aires, and autopilot and other cruising gear...in 2012
Ill let you ponder how cheap I sold this boat ready to cruise for:D jajajajaaja
Corsair 24
Why did you not sell it to me? You know that I would have bought it. I will look up norvane now. The fact that they are in California helps.
I came on here last year...didnt know youback then bud!
would of loved to sell it to someone like you...EAGER
peace
Discussion Starter · #15 ·
I called and talked to the owner of norvane. I think I am going to try and keep the cost of the boat down a tad so I can get one of these. Less than $2500 with the spares kit and I can install it myself without hauling out.
I thank you for pointing these out. They are in California and are cheaper and I will have it made for the boat I get. Think about it, I will finally be able to sail anywhere!
One might do some research on the Norvane and talk to folks who have used them before writing the check. With the Aries, Monitor and Cape Horn you know you are getting a vane that will take you anywhere in all conditions. I believe that Norvane is a new player in the market. It may be super...or it may not, but research is appropriate.
Not all that new. Here is a link to a circumnavigation with one on an Alberg 30 readied for the trip by James Baldwin (Atom)
Atom Voyages - The Salsa Voyage
A few years previous to this James outfitted a Triton with a Norvane and the owner sailed across the Atlantic without problems.
What's happened to Cape Horn?
Yves wasn't at the Annapolis Sailboat Show this year ... and when I tried to go to his web-page, I was re-routed to a French-language web page at "suppornet.com" ...
1 - 20 of 20 Posts
