I am in the process of re-bedding my chainplate and I have a little unusual set up and am looking for some advice. Our deck plate is integrated into the chainplate and bolts to an interior bulkhead. The damage to the woodwork was noted in the pre-purchase survey but the listing broker may have exaggerated the level of work done to address.
The factory install was nylon washers around the 4 thru bolts to provide a 1/16th inch riser for a thicker mat of sealant (5200) with butyl on the bolts. The bolts did leak a little but the deck seal really failed, and water intruded down the plate and into/off the bulkhead regularly. There is about 1/8-1/4 of an inch of space between the outer diameter of the chainplate and the inner diameter of hole in the deck. (All residual 5200 will be removed to get surface pristine and as much as is possible in the thru-deck)
As I re-bed, I am reluctant to remove the washers because the bulkhead bolt/bolt holes will be off by 1/16th. I would like to use a mix of 3m 4000uv and bed-it butyl. I do want to increase the inner diameter of the washers to allow more butyl there, but use 4000 for the bulk of the sealant and butyl in critical locations.
My concern is that if the innermost area adjacent to the chainplate is thick butyl without any restrictions, will it creep in hot weather and fall into the interior making a big mess? the chainplate vertical edge to the edge of the flange is 3/4 inch at the narrowest spot.
thoughts or recommendations?
wayne
wayne
