1 - 6 of 6 Posts
Abysmally Stupid
In the search for a new boat, I have come across a couple of potentials with blue hulls.
How hard would it be to change a (I assume) painted boat name on a painted blue hull?
Boat is a Bene with a hull painted from the factory.
If the hull is blue gelcoat, and the name is painted on, you can often use Easy Off oven cleaner to remove the name.
gonna have to buff the gelcoat out real good once you remove the name, more than likely there will be some fading to minimize.
Abysmally Stupid
Discussion Starter · #6 ·
Lads,
Thansk for your help.
we used the de-naming / re-naming procedure on the current ship.
It was succesful, I think. She still floats. Did float 0.5 hr ago when I went down to check on her and had me a wee Macallan...
Cheers.
1 - 6 of 6 Posts
