1 - 20 of 33 Posts
Discussion Starter #1
Hi, folks. New member here. Weeks back I was a thinking about possibly taking on a 30' boat that, while serviceable, needed lots of love, AND was moored, because, well, it was too big to trailer. I decided not to go that route and started passively looking for trailered boats that I could convince the Missus to let me buy and throw money at.
This *is* last notice, as I just saw the ad today, so I don't expect a lot of response, but I'm hoping for a bit of advice before I go see it tomorrow at lunch time.
Don't have a hull number, but I know it's a 1971. Hardware was removed for paint, but seller bought a bigger boat instead. Boat hasn't been painted. Hardware is on hand. Seller says hull is sound, with no soft spots. Sails are serviceable but will likely need to be replaced after another season or two. I know how to sew and will likely buy a Sailrite kit to replace them to keep expenditures lower.
Boat and trailer are both titled; don't know the condition of the trailer; seller says it's road worthy with working lights.
No motor on the boat.
Price is too good to not go look at.
So, having said all that, what should I look for and what should make me run away?
Goals:
I know the basics of sailing, having learned on a Flying Scot, but I need practice and a guide before handling a boat alone. I've read this is a very user-friendly boat for beginners. I live 10 minutes from a ramp on the Patuxent River in Maryland at a wide, slow, gentle spot, and am about 20 miles from the Chesapeake Bay. While not an ultimate fishing boat by any measure (rigging and such), with a small motor to reach in closer to shore easily, I can at least take my kids out on it to toss a line off the back.
Thoughts?
Hmm, translation of Seller to English:
Seller: I took everything off the boat, but then decided I'd rather have a bigger boat
English: I have no idea where all this crap goes.
Seller: I took off all the parts but the hardware is on hand.
English: I know the bag I put everything in is around here somewhere.
Seller: Good sound hull with no soft spots
English: Well it was sound when I put it in the barn, I can't understand how your foot went through the deck?
Seller: The sails have another couple of seasons in them
English: I put duct tape over where the rats chewed holes in the sails, that'll hold you for a while.
Seller: The trailer is road worthy with working lights
English: The trailer will be road worthy after you rewire it, replace the lights, get new tires and replace the hubs. Other than that it doesn't need anything.
Seriously, these are good little boats. They're simple to work on and there are a lot of owners out there who can help you with where all the hardware goes and whether anything is missing.
Forget Sailrite, go over to Bacon's in Annapolis. There are a lot of Mariners out there and I'd be surprised if you can't pick up sails for $200-$300 each.
As long as the hull is solid you can have her on the water for a few bucks and some elbow grease. Enjoy !
Master Mariner
Beware! In cases like this the buyer often spends way too much time and more money than the boat is worth to get their purchase up to sailing condition.
Most would have been much better off spending a bit more money up front and spent the time they would have spent fixing up the boat, sailing instead.
Reactions: jbswear
Discussion Starter #4
Jim,
What you described sounds a lot like motorcycle sellers I've run into! Thanks for the advice.
capta,
From what I've read so far about repairs and remodels done to this model, not a whole lot is needed; there is very little wood on the boat to rot and replace, and I'm handy enough that I can rebuild the keel if it's in bad shape. I'm a woodworker by hobby and have built a motorcycle from scratch, so those skills should serve me decently. But yeah, I'll check the weak spots and the mast before committing.
Master Mariner
Jim,
capta,
Boat building (repair) is a completely different skill set than carpentry. They are about as far apart as a motorcycle engine is from a diesel.
If you decide to go ahead with this project I wish you good luck.
Discussion Starter #6
True. I also have working knowledge of laying epoxy and fiberglass. I'm no artist when it comes to it, but I can make a workable mess out of it.
There are some diesel motorcycle engines, and gas and diesel engines work in similar ways. ;)
I would think that as long as your expectations are realistic it could work out fine. It'll likely cost 2-3x what you expect to get it back on the water, and take at least twice as long as you hope. Having said that... Get the kids involved, let them help along the way. That way they learn some skills and you all get to enjoy the boat long before she's on the water.
Sent from my Moto E (4) Plus using Tapatalk
Barquito
If the boat is in otherwise very good condition, you should be getting a huge discount. If there are issues (other than the sails, and the deck being a jigsaw puzzle), you might possibly point out the cost of disposing of a boat and offer to take it for free. Most people, including boat owners, do not realize that boats can have negative value.
Discussion Starter #9
Oh yeah, I know all about how far off time and cost estimates can be, especially for a novice, so I'm not even going to make those estimates--I turned down a *free* 30' cruiser because it needed too much work. What I'm looking for is advice on what to look for when I get there.
Here's what I know so far:
Check the hull all around. It's on a trailer; this will be fairly easy.
Check the deck.
Check the joints between the transom and the hull.
Check the mast for damage.
Check the mast mount for sinking/damage/cracking.
Check the centerboard for damage, particularly the bolts that mount and lock it in place.
Check the centerboard trunk for bad cracking.
Check the hardware mounting points for cracking.
Am I missing anything?
Jim,
I'm sure you can, but would you want to pay for the privilege of doing so, instead of spending time sailing? If you're hobby is fixing boats fine, but the price of a boat that works and ready to sail is generally much less than the fixing cost of a "good bones" boat, not to mention your hours..
Check the deck.
Bulkheads
Winches
Moisture
I think a Mariner could be a fun project. They're simple boats without complex systems or electronics. A ton of them were built as the O'Day 19 and Rhodes 19, and Stuart Marine is still making them today, which means you can still get replacement parts if you need them.
If you go to the web site for the Mariner Class Association at https://www.usmariner.org/ there's an article on what to look for when inspecting a used Mariner (you'll have to join to get access to the site).
Some other sites to check out:
The O'Day Mariner site on SailboatOwners.com (https://oday.sailboatowners.com/resources/index.php?task=model&mid=136)
Stuart Marine (https://store.stuartmarine.com/)
Best of luck with her !
Discussion Starter #13
I bought it. For a 49 year old boat it's in great shape. Pounded all over the hull, no hollow sounds or flexing. Bounced on the deck, no flex. Visible patching in places; paint not yet applied. Seller gave me the white paint for the deck; I'll buy a different color below.
Sails are fair. Rigging looks wonderful. Sheets need to be replaced.
Plastic trim for seam between deck and hull needs replacing. Tiller and rudder are in great shape. Center board looks good.
Trailer is in fair shape.
Eight years out of the water, covered.
For $250, not bad. I'll be joining that Mariner forum.
Singlehander by Default
For $250, I doubt if you were taken to the bank by the seller. If he gave you all the hardware that he had, then it should be a pretty decent project for you and an awesome learning experience. Have fun, enjoy the build and get her out as soon as you can.
Discussion Starter #15
Yeah, this year will be getting her on the water in the shortest time and with the least expense. If I find I and my family love sailing, I'll look into making her pretty.
Congratulations !
For $250 I think you got a great project boat. Best of luck with her.
Hi,
Congratulations!
Some simple advice:
Do as little as possible to make the boat 'sailable.' Don't spend money on upgrades, paint, electronics, sails, fancy lines, new electrical system, etc.
Do make the boat safe. Do buy some PFD's. Do buy a cheap reliable motor.
Then practice rigging and unrigging the boat. Then go sailing. And sail as much as possible.
After one season with you boat you will know what to do next year.
Have fun.
Barry
1 - 20 of 33 Posts
