1 - 9 of 9 Posts
Awhile back I took our sails in for a cleaning, they were not good , rust stains , black ( mildew ?) stains . The loft assured me they would look like new , I'm thinking haha their 30 yrs. old . I got them back and they did little more than hose the dust off . I felt ripped off . But they only charged me for one and I brought three , so I just went back to the boat . Anyhow how do you guys clean your sails ?
Most sails that need cleaning really need replacing. It would be a rare situation that would create an aged dirty sail that still had any shape. I've never seen such a sail.
· Junior Member
I give mine a regular rinsing with fresh water when dock side. A few weeks ago just sponged them down with laundyy detergent and a good rinse. Came out quite nice. Maybe a regular clean up will work better then waiting until they are really dirty?
Reactions: christian.hess
· Premium Member
... Maybe a regular clean up will work better then waiting until they are really dirty?
Absolutely that's better. But ours were dirty when we bought the boat. The cleaning suggestions are good for those cases, too, when the dirt is no fault of the current owner.
Reactions: Markwesti
Most the 'dirt' in sails is either fungus/mildew or iron/tannin staining.
Again just like cleaning mold and mildew inside the boat, the same 'chemicals' will apply to cleaning woven polyester dacron .... (NOT for laminated sails including 'cruising' dacron laminates):
Firstly, clean with a mild/diluted 'caustics' such as sodium silicate, TSP, lye based detergents. Spray-on/Wet out with the caustic, cover with a plastic tarp to soak (one hour, etc.) and let the caustic dissolve the funguses etc.; scrub with soft long handled bristle brush adding just enough water to keep the fabric wet and repeat, repeat, etc. as necessary. THEN thoroughly rinse with water.
Secondly, to remove iron, rust and TANNIN stains and discoloration (picked up from the water) .... obtain oxalic acid crystals (a pint) from a paint/hardware store. Keep adding the crystals to a gallon or two of HOT water until the crystals no longer dissolve .... use the soft bristle brush to apply the oxalic solution --- should almost instantly remove the iron/rust/tannin staining. Thoroughly rinse with water. THEN thoroughly dry the sail(s).
Best is to do this ON the boat (BUT not on a boat with NO exposed or bare teak, etc. !!!!!!!!!). On a windless/humid/cloudy day, just raise the sail as needed to apply/scrub/rinse, etc. ... then go sailing to dry the sails. But you'll then have to re-wax the boat as the caustic will strip the wax off the gelcoat.
Beware Oxalic Acid - use 'protection' - gloves/goggles/etc. as oxalic will rapidly absorb through your skin/corneas and collect in your kidneys as needle-like crystals that can/will destroy the nephrons of your kidneys. Without protection and at a minimum, you'll risk winding up with kidney stones. Use 'protection' when using oxalic acid.
· Junior Member
Sodium silicate based detergents seem to work 'better' on woven dacron polyester.
Missed the old "Tide", the local purple colored detergent seemed to work pretty good. I recommend a good floral scented powder, Frangipani is my flavor of the month. May try and spot clean a few rust marks with the TSP...
Reactions: RichH
1 - 9 of 9 Posts
