1 - 13 of 13 Posts
Sea Slacker
I had my mast re-stepped today and rigger chose to put a top forestay pin in "upside down" (i.e. with the cotter pin towards the forward/up). They explained that this is to avoid chafing halyards. The explanation makes sense but ever since then my "safety paranoia" keeps me worried - what if the cotter pin comes out or breaks somehow? With the cap up - clevis pin stays put (at least for a while) - with the cap down it pretty much falls out right away, doesn't it?
Should I go up the mast and reverse it? Or stop being paranoid? :) :) What would you do? (Where is knothead when you need good rigging advice :) )
Actually, I was asked to flip mine to the way yours is by a surveyor.
How close is close?
Chances are likely, if your forestay is anything like mine that it wouldn't come out even with out the cotter pin in... the top of the forestay is often too close to the mast when the mast is up for the forestay's upper cotter pin to fall out towards the mast.
Just check it with your binoculars on a regular basis. I would not worry about it. As Sailingdog mentioned - the pressure against the pin will most likely hold it in place should the pin ever fall -out - which is very unlikely.
well, I take it no one thinks its a big deal - good :)
I was waiting for Knothead to chime in.
But I agree with the others. Those cotter pins are plenty strong enough, and they're not even under any load. The clevis pin takes all the load.
Sea Slacker
Discussion Starter · #10 ·
zz, btw - your signature reminded me ;) those 4hm 2 stroke motors are hard to come by. I bought mine on eBay last year after a lengthy search (and had to spend quite a bit to have it properly serviced).
They are worth their weight in gold :) Sorry, no useful advice - just keep searching eBay and one must come up.
There isn't room for much in there...
How close is close?
One the other hand, the pin ain't falling out.
One way to get more space would be to go with high-tech line, which I am considering. As you can see, the spin halyard is moving around in the same space.
Sea Slacker
Discussion Starter · #12 ·
that's a tight fit. I think my mast actually provides enough clearance that chafing may not be so bad (but on the other hand should anything happen to the cotter pin, clevis pin certainly has more than enough space to back out and go AWOL)
An example of a good surveyor.
He looked at everything and took MANY photos. Removed every panel on the boat that had wire behind it.
It was worth the money. Even though I would have eventually seen things like this, he brought thing to light that might have gone unseen for years.
1 - 13 of 13 Posts
