Kevlarpirate, it is very difficult to have a meaningful discussion with you. Besides the arrogance you seem to put very little discipline and methodology in the way you think. You think more like a pirate and less like a scientist
As an example look at this:
I say on post 67:
"In what regards motion and speed, the importance of the LWL is…noticeable."
On post 69 you imply (disagreeably) that I don't know of what I am talking about.
On post 76 you agree with what I was saying on post 67:
" I am nor disagreeing that bigger boats are not faster and more comfortable".
It is not possible to discuss anything this way
Five years ago, on this forum I have posted a thread about this subject (seaworthiness, boat design and comfort) and as you can see, I was saying about the same things you are saying now.
Of course in 5 years I have learned a lot more and even if what I was saying is basically correct I have found that there were other points to consider, some technical others that have to do with living in the real world. People have a certain amount of money (not much, unfortunately) and they want to buy the more comfortable, seaworthy and fast boat they can get, and that is what really matters to the vast majority of people.
I suspected that I was basically wrong on the way I was seeing things because the best world Architects were not designing (not even for their personal use) the kind of boats I thought they should be designing and, because I don't have your Ego, I started to suspect that I was not understanding something. Since then I have a much better understanding of what they are doing and why and that has permitted me to have a much better understanding of boat design, the advantages and disadvantages of each type, even in what motion comfort is relevant.
A quote of some of the things I have said on that thread:
"....And about sailing, there are many differences in the kind of sailing (traveling). There are the ones that want to go as fast as possible with a full crew, others want good speed but a boat that can be easily solo sailed, others want maximum comfort in a seaway others an optimized safety, for the size of the boat. There are a lot of compromises to be made (in hull shape and rig), originating completely different boats, depending on the assumed different priorities…..
It seems to me that you think that weight (mass), besides the one needed to give the boat stability) is always a bad factor in a sail boat.Although I agree that mass is always a bad factor in a racer or even in a cruiser-racer, it is not (in my opinion) in a pure cruising boat with priorities aimed to have an easy motion, maximum safety and lots of autonomy.
…. I believe older boats, even old racing boats, are normally "less radical" than most of modern boats and have a smoother sea movement. They have a less flat hull and have more ballast, depending less on form stability……"
http://www.sailnet.com/forums/general-discussion-sailing-related/11338-how-heavy-too-heavy-ii.html
Regarding this thread and your posts, instead of discussing each point at a time you make a lot of claims and statements as if you knew everything about this topic and other opinions should not even be considered. I would say that, if not for Jeff (he asked me), I would not be around this discussion. I like to learn and I have learnt a lot in the last years, but I doubt I can learn something that way.
Let's see if I can answer some of those somewhat disconnected statements that you have made:
…, just trying to save Paulo some headaches and money.
Anyway, it sounds like Paulo knows which way he would like to go, ... …..As a note, IMO, I don't think Paulo really cares about comfort. I think he wants speed. Perhaps he wants it all. My point is that he can't have it all.
Any manufacturer of a sport boat who adds 300 lbs of interior and calls it a cruising version should be spanked.Yes , you can cruise in it , but to dupe someone into thinking it will be comfortable only means that that someone has never cruised any where.
kev
It seems that you know more than myself, regarding what I want
. Fact is that I am quite sure that I can live happily with different types of boats (each has its own advantages and disadvantages) from broad sterns to canoe type boats (small beam). It all depends on what appears on the market at the (very) right price.
What I really know is what I don't want and that is an old designed boat. I want a modern design, a fast seaworthy boat, adapted to solo sailing with an interior suited to cruising and a boat that is fun and enjoyable to sail. I also want a boat that can go better than my older one against the wind on short period waves.
Comfort is one of the variables. Certainly I would not have a slow boat or a boat that is not agreeable to sail, but to be more or less comfortable is a question of tradeoffs. What do I lose on comfort, what do I gain on seaworthiness or speed? Each (kind of) boat is a case, to be studied separately, as the occasion arises and anyway, this is not relevant to this thread.
If he wants a flat boat, he will most likely have a bad "computer generated" ahem.... static curve to sleep with. That's his choosing, sweet dreams
If he wants high tech thin materials , he will have a noisy interior,
and be serenaded by slapping waves against his hull all night long while tucked into one of those nice coves there in the Med.
kev
I am pretty sure that I know more than you about stability curves, that, as Bob Perry has said (or any other boat designer will say), are the tool that you use to access boat stability, while designing it.
You seem to have a comprehension of what is the goal in designing a certain type of stability curve, but wrongly assumed that a certain type of Stability curve is the model from all other types of sailboats. Different sailing boat types have different kinds of stability curves that show the advantages and shortcomings of each type of boat, in what regards stability. In the last years I have looked over many different boat stability curves, trying to understand the options the boat designers have intended in designing a boat with that kind of stability.
You are not going to learn much if you assume that there is a correct type of stability curve and that all the others are wrong.
About hi-tech materials and the noisy interior while at anchor, you are wrong.
Old boats (and some modern ones) are built with a single skin (solid laminate) while hi-tech boats used a double skin with a core at the center. The double cored skin will insulate the boat from sound and temperature far better than the solid laminate, no matter its thickness.
If he doesn't mind having to ride 6 feet above the water on the high side rail to steer..If he doesn't mind having to steer perfectly in the slot 100% of the time and be constantly playing the main, that's great, good exercise too.
by the way, heel is a good point , and to that, I have a variety of headsails and typically use smaller ones and never go over much over 20 degrees…..
kev
That is a very confusing statement. You mean that if in your boat you can go safely faster but have a heel superior to 20 degrees you would change for a smaller headsail, going slower? I am not that kind of sailor and I don't think you are either.
Different boats are designed to sail better and faster at a determinate angle of heel and almost all racing boats (older and new) and all narrow beam boats are designed to sail better (close to the wind) around 25 or 30 degrees of heel. My boat worked that way and yours too.
The only boats that are designed to sail with not much heel are multihulls and modern boats based on the design of Open racing boats, boats with a big stern and two rudders. These boats are designed to perform between 10 and 18 degrees of heel. You are not going faster if you push the boat and can even go slower.
If this kind of boats heels very little, how can I go 6ft over the water?
And if this kind of boats are designed for max stability and solo sailing why do you say that I would have to
"to steer perfectly in the slot 100% of the time and be constantly playing the main"? That is quite the opposite, these are the most forgiving boats, boats that are made to go on autopilot on bad weather while their solo sailor is sleeping or resting in the interior.
… The single most important ability of a sailboat is it's ability to sail upwind in strong winds and a developed sea without getting beat up. …
Many sailors would rather sail off the wind , that's fine , we all have our preferences kev
Certainly a sailboat should have the ability to go upwind but to make that its most important ability, I disagree. Even in what concerns racing boats, particularly Open formula boats where you have the freedom to design more or less beamier boats, the boats designed for Open races are big transom boats, boats that can go well upwind but that are optimized to sail downwind.
That means that even on circumnavigation races going close upwind is far from the prevalent conditions. That is a lot more relevant if we consider cruising. Cruisers only go against bad upwind conditions if they cannot chose otherwise and in 99% of the cases they can and wait for the right wind.
Englishmen have a say:
"Gentlemen don't go upwind".
I would not be so adamant, but going close to the wind in bad weather certainly is not the first choice for cruisers.
Of course, I agree that, for safety reasons, a boat should have the ability to
"sail upwind in strong winds and a developed sea" but making a priority into being able to do that and moreover in a relative comfort, it seems a vast exaggeration. Anyway your term "beat up" is imprecise. If it means what I think (pounding?).
Most modern big production sailboats have that ability, depending on the wing angle. A boat optimized for those conditions can go at 30 degrees or slightly less and a typical mass production cruiser can go at 45 degrees.
Optimizing a cruising boat on the ability to go upwind makes no sense to me and I would say, no sense to the boat builders and naval architects and that's why you don't find them on the market, unless they are cruiser racers and therefore intended to race upwind.
As for a definition of what comfort really is, that is subjective. ...My Ericson 46 is very observably more comfortable than the SC50.
…but again, if you were to interview crew after the SC sailed a circle around us I would be willing to bet the SC crew never even considered discomfort as an issue.
kev
Well, it seems that I am not the only one that considers the relative comfort as a tradeoff and not an absolute item
. And if you will let those guys chose between both boats for going on extensive cruising (providing both have similar interiors) I believe most of them would chose the fast and more modern boat.
I agree with you (finally
) on the subjectivity of the definition of comfort and what I have said in the beginning of this thread seems to go accordingly:
"The tastes of different sailors about the kind of sea motion they prefer, varies a lot. What is comfortable to you can be just boring and devoid of any sailing pleasure to another cruising sailor.
The type of comfort motion you like is a very personal thing, and varies as much as the different kind of cruising boats that are suitable to do Ocean passages, from the relatively heavy boats that you favor to the fast cruising racers, or Open type boats
I have owned a heavy displacement boat and I have owned a light displacement boat. I do prefer the motion of the light boat, not in all situations but on almost all of them. You have seen that on this thread I am not the only one that thinks that way. That doesn't mean I am right. There is not right or wrong here. Sailors should try both kinds of boats to see the difference in type of motion and to make a personal choice."
Saying otherwise, and going with your mass theory as the absolute panacea for comfort, would be implying that multihulls are less comfortable than monohulls and that seems a quite extraordinary statement considering the huge growth in popularity of monohulls among cruisers.
Ted Brewer, the one that created that comfort ratio formula also agrees with you on the subjectivity of comfort (and sea motion). He says:
"Nor will one human stomach keep down what another stomach will handle with relish, or with mustard and pickles for that matter!
It is all relative."
