Very interesting read on the carbon masts. Thanks Viking
The very good points he makes are that it improves the ability to carry sail. That is fun.
However, short of doing a FEA, it could result in substantially higher dynamic and impulsive loads on the rigging , chain plates mast step, mast compression and hull. The static solution to the problem by removing mast weight, cannot be
assumed to be equal to the new dynamic forces of higher sail loading. It may be nothing to worry about in the end.
My rigging buddies in Florida tell me rigging failures are not mostly from high winds with deep reefs ,and no.3’s, they are more common using heavy no.1’s, under 20 kts.
Other good points are aluminum masts can develop stress cracks as he mentioned. I have seen this on a couple of production boats which, to save assembly time, employ trick designs, for instance spreaders being held by one big pin drilled through a casting
The casting being very solid produces a stress riser on the thin walled aluminum tubing and guess what …. Cracks. My 30 year old triple crane Sparcraft (both boats) have none of these problems. Personally I would dread ever losing them.
Because I may end up with something I don’t trust.
Another very important point is the paint issue. 6ooo series aluminum is alloyed with copper and is prone to that white bubbling which is very unsightly and it happens to all masts, even the ones well primered with zinc chromate. Sooner or later it happens, and the cost of repainting is very painful as he states. Another reason I am very protective of my masts. And regularly check my rigging. They are anodized and after 30+ years, I have no issues,
The author also states exactly the point I have been making re: moment of inertia.
He states twice the jerky movements. One statement he says he was seasick.
This is exactly the price you pay for the fun factor. It is the comfort factor.
Jerky movements are high accelerations, nothing else.
When I mentioned cutting a wave in half and looking back at the hole we just made
That is my fun factor, I would rather do that than realize another 2/10 of a knot
because I can take my number one up another 4 knots true. But if the extra 2/10 rings your bell, then great , it’s your boat.
When I cut a wave in two , I don’t want to feel the boat pitch up. I want to blast through it. To me it’s kind of like the feeling I would get driving a monster truck over a car and crushing it. Now perhaps some of you are more sophisticated than me, but I like crushing things.
A note I can make about carbon masts is they are not as torsionally stiff as an aluminum mast, so if you have swept back spreaders, you have some considerations to deal with as for standing rigging.
One issue I would disagree with the author is with lightning strikes.
I had my 41 in Florida for 8 years and was blessed by not getting hit, however I have
been close, so I will tell one account here . I had my boat in the yard and got a call that a boat next to me was hit. I raced down to the yard on two wheels around every corner ran to the boat to see the damage. First I can say, I made a couple of grounding spikes and had them pounded in the ground and cables up to the headstay and backstay , so I hoped they worked if I got any of the strike. My shrouds are connected to the keel by ¼ inch copper tubing conductors, so I was not worried about that, also I have one of those fuzzy things on the mast head.
The boat next to me did get hit and on all six jack stands where the pads met the hull
The hull was pierced from the current. The jack stands had all been moved off to the side. Each area was black with soot where the resin was carbonized and missing.
You could take a pencil and push the glass fibers around and push the pencil right through to the inside of the hull. Some holes were worse than others.
The energy of an average strike is in the order of 200 kilojoules, about the energy of a hand grenade. That energy has to be dissipated somewhere. The current also shot
Out the transom somehow and ended up in the boat behind the struck boat , so obviously there was plenty of energy there to do damage.
My point is this: all resins carbonize around 450 deg. F. so one would expect serious damage. Especially along any path where current must run on its way to ground.
This could be between the mast head and the upper shrouds. The resin is a essential stabilizer for the fiber. I don’t know how well the carbon conducts in such an event,
However, I would need much more data to convince me they are safe for a strike.
I would talk to insurance claims people first.
Paul , My statements referencing physics and boat behavior are all consistent back to my first post. If you don’t find any thing of value, then just don’t read my posts and let others judge for themselves.
One note I will make is that I attempted to make a definition of what comfort was
and was not . I proposed acceleration was the most likely agreeable definition.
No one came forward with any other definition. Including you.
The best that could be proposed was that it is different things to different people which gets us no where.
What is obvious is that comfort and motion produced by light weight boats are opposite. You can’t have have comfort on a sport boat or a ULB, in a developed sea unless your definition of comfort includes black and blue marks .
Paulo, did you read the insurance claim article? Humerous too. I don’t doubt
There are better cats than others for passage making, but again when a 76 foot cat
Capsizes in 8-10 foot seas, that scares me , I would guess it was as simple as burying the lee hull , I have done that plenty on the Hobie, and I don’t see any reason you can’t scale that problem up. Gone for the weekend here . cheers, kev
