1 - 4 of 4 Posts
Freedom isn't free
That lever on the top should move, likely forward. if it does and the mount doesn't come back up automatically, you may have seized springs, whatever you do DON'T get your fingers near the pinch points if that lever is released... Have a friend who lost the tip of his finger that way.
The alum sometimes corrodes together... not sure what'd break it up, but I'd probably spray some WD-40 on it if that is what is seized.
If the lever itself doesn't slide, a tap with the hammer might help free it. Again keep hands away from pinch points, the mount might spring up quickly without weight on it.
Agree with everything SHNOOL said. I have the same mount and without any weight on it, it's difficult to get the lever to move. Put a little downward force on the wood block then try moving the lever
Freedom isn't free
Yeah, forgot that these mounts are "safe-est" with a motor on them.. without it, they "spring" with LOTS of force.
1 - 4 of 4 Posts
