1 - 14 of 14 Posts
Discussion Starter · #3 ·
LOL,
wow, what a complicated profile. Have you tried the mfg of your boat?
Errrr, no. Firstly they went out of business in the 80's and the photo is not of my boat, its a 30 Hunter and they are no help.
I'd Google 'aluminum extrusion' or 'extrusion profiles' and see what that gets.
Good old "Mr. Goggle", why didn't I think of that? I must be too busy googling "Kardashian + bikini."
Sorry Multihull girl, you did give me a good laugh and I don't want to be too unkind AND you did bump my post back up.:)
Fair Winds
Gerry
I get you, but plenty of people don't start at Google, you gotta know that...
that is one wacky extrusion, though. I'm feeling your pain, although I'm trying to find a portlight gasket extrusion that i can only describe as a 'P' with a serif on the foot of the 'P' shape. G.Zeus! who invents this crap?
LOL,
Fair Winds
Gerry
G Tod, there's your problem. Mr Goggle knows jack about aluminum extrusions, try Google instead. There are literally thousands of profiles available if you own cutting tools.
That extrusion - is it your boat or do you just want one like it for your boat?
Looks pretty specialized - maybe a special run for that builder. Check the hurricane derelicts you might get lucky.
islander bahama 24
My father in law has an old chart from Boeing that shows that exact extrusion don't know much beyond that it was origionaly specific to airplane construction.
Well there's an interesting 're-purpose' :)
This is actually a very simple extrusion. The problem with extrusions is they are so cheap to design that anybody that can justify 1000 lbs of it will have the die cut and pass the cost off to the customer. A die like that is about $1500. The cost of aluminum is about $2/lb. So a part like that is about $10 of aluminum and $3 in finish. Add $5 for drilling and cutting. But you'll pay $125/pair if you can find them. Go figure.
I literally work every day with aluminum extrusions. I am an architectural designer. If you really need these, I can show you how to fabricate some pretty nice replacements for short money. PM if need be.
Don
Learning the HARD way...
Don
Why not post here and show us all?:confused:
We'll give you REP Points if you do!:)
Master Mariner
As mentioned above, that extrusion might be a lot more easily found than one might imagine. What I don't understand why you are looking for that when a standard yacht hatch slide mechanism is stronger and much simpler. I do not see any advantage to using what will most likely be a non-marine grade aluminum extrusion and re-purpose it for your hatch.
Sorry about the pic quality.
1 - 14 of 14 Posts
