I hate to discover process errors after the fact, so I’m hoping for some additional comments/opinions regarding my hatch project. I do have some assistance from someone with much more experience than i have.
I have removed the two bottom layers of wood; approximately a 3/16” layer of plywood, and a 1/16 layer of decorative veneer. They were fitted into the 3/16”-1/4”channel in the frame sides, below the teak planks. I am trying to clear (difficult) that channel (see pic) of all the broken end pieces from those removed layers. Some of the teak strips have gaps. I’m planning a 3/16-1/4” layer of FRP or marine plywood with resin/epoxy, to fit into the surrounding channel. Do I need cloth?
The teak strips are about 1/4“ thick and may be backed to a very thin attached veneer. Are those strips individual strips or glued to a backing veneer that made it one complete sheet? In the attached picture you can see that layer, and that some of the teak strips have separated by about 1/8” max. How should i close those gaps? I have some long bar clamps that can be attached to the sides of the frame and be tightened to pull the sides in, to close the gaps. Then i can epoxy/resin the bottom layer of teak and install the replacement layer. I’m concerned that when the bar clamps are released, the built-in pre-stress tension could cause the repair to crack, separate, and fail. Should i close those gaps another way; or ignore them and fix with the black caulking later? It seems that i should epoxy the bottom of the teak layer prior to installing the replacement layer, but that epoxy can seep through the gaps to the top of the teak strip.
Strength question: If I can’t use the channel, did those of you who already rebuilt your hatch use the frame channel or add wood strips along the sides to secure the new panel? Also, did you glue the strips and/or glue/epoxy the new panel to the bottom of the teak layer?
Because of the concave horizontal curve on the fore and aft end of my hatch frame, and upward curve of the hatch top, the added FRP or marine plywood layer may have to be cut in half horizontally to slide the ends into the fore and aft ends of the channel. Inserting the new layer into all 4 sides of the channel will be more difficult (maybe impossible). Agree?
Other ideas, insights and criticism are welcome. Thanks.
