1 - 20 of 31 Posts
Learning the HARD way...
Discussion Starter #1
I had the yard pull my mast last season. The charge was $6.50/foot to "Step/Unstep Mast." Storage was extra. My thought was that it was $6.50 for BOTH stepping and unstepping. Today I received another bill for $6.50/foot for "Step/Unstep Mast" presumably for the cost when she was launched..:confused:
Am I being cheap? Should it cost $6.50/foot to unstep, and another $6.50 to step the mast? Or, am I being hosed - again...:confused:
Also of note - I instructed the yard to soda-blast, barrier coat, and apply 3 coats of paint (1 red and 2 blue), that I supplied. They did a great job with the soda-blast and barrier coat. However, they either painted the bottom with 1 coat of blue, or they used one gallon to cover a 35' boat with a 6' fin keel. I'm NOT believing that:rolleyes:. To be honest, I am not sure that they even applied the 1 coat of red to my boat (as opposed to someone else's).
Discussion Starter #2
One more tidbit; when they painted the bottom, they also painted my depth transducer. As a result, it was inoperative. After launch, I scrubbed off 1 coat of blue bottom paint (no red) with a bronze brush, and voilla! it worked - for that day. (Now you understand my suspicion about the number of coats.) Since that 1 day, it has been completely inoperative. I have tried sanding with 400 grit several times, and still no joy. The sounder is a circa 1987 Signet Marine unit - worth about $20...
I had one yard charge 800 to unstep and step a mast on a 28 footer and another 10 miles away charge 1/2 that to do a mast on a 35 footer - 50 ffet of mast. They charge what they can get away with.
Discussion Starter #5
OK; $325 to unstep, and now $325 to step.
Cost for the mast in and out doesn't sound out of line. Doesn't sound like they put on the three coats of bottom paint you asked for however.
Yard here charges a set fee to unstep/step mast $60 if boat is out of the water (more if boat is in the water and/or if you have to make a special appt). Max price $90+$50 for dock, that boom truck can drive on,use.
I just recently paid $600....that included hauling the boat, mast out and back in, being n the yard for 12 days and put back in the water (plus labor for rigger to help replace standing rigging).
Aspiring to be a Mexican
Mine was $130 to unstep and $260 to step in Alameda, Ca. I did most of the work but I don't own a crane so I had to pay the $130.00 per man hour for the crane and two guys. I still feel a little bit ripped off but not like I need Preperation H to fix it.
Super Moderator
That's a little steeper than what we pay around here but pretty much in the range. For a 55' spar I am at about $175.00 down, $250.00 up and $110.00 for indoor heated storage where I can work on it in the winter if I need to..
I think $325.00 is certainly in the range. I am always there when our spar is stepped. Two guys + me and about four+ total hours of work not including bending on the sails just stepping, tuning pinning, rigging.. Just retrieving the mast from the rack, untying all the rigging, installing the spreaders, VHF, windex, wind transducer, spreader boots and testing all the wiring before stepping was a solid two hours of prep. A spreader bolt galled, as happens from time to time, so that added about 20-30 minutes but this type of stuff happens. We then have the Spartite, mast boot, mast drain, mast wiring in the boat and all the other rigging like the lazy jacks & furler to rig.
As for your bottom paint I regularly get our CS-36T done with one gallon or Pettit Ultima SR... The MOST IMPORTANT step is to make sure the yard hot coated the first layer of bottom paint to the last layer of barrier coat. Many yards royally "F" this up and totally miss this critically important window..
When I paid to have our boat done I put it in writing that it would be hot coated per manufacturers instructions and made it a point to be there when they did it. My yard was honest and missed the window and owned up to it. It cost me another gallon of barrier but was totally worth it to have it properly applied.
Discussion Starter #13 (Edited)
Thanks all!
I had initially wanted this thread to be a little vague, as I believe that the yard owner is a good guy, and I believe that he may come across this thread. However, I have since decided that he should know, that I know that his price is OK.
Also, I will discuss the bottom paint issue with him. (BTW - he charged $75/hr for this service.)
As I keep telling myself, if you want a job done right, take your time and do it yourself! However, because I landed a job last year, I am now chronologically challenged (time is scarce).
Down here i pay something close to 900 round trip with outdoor rack storage so i do not have to keep the mast on the cabin top
To be honest they do a good job and don't dammage anything as to store 4 or 5 hundred masts they have to remove and replace the spreaders, wind stuff ect
I know people who have done a spread sheet on every marina in the area and the total costs are all very close as waterfront is big bucks on LI compared to some other places
Wow! Remind me not to move to the east coast. $45 down,$45 up and $50 outdoor winter storage off the boat. Keel stepped with mast length of 45 feet.
Super Moderator
I suspect your yard is going to get a "green card" visit....:D
$45.00 is about a 40 minutes labor for one guy around here. It took 25 minutes just to get our spar from the rack to the rigging area using two different cranes and a mast dolly....
$325.00 / $70.00 hr = 4.6 hours for one guy.... That is moving pretty fast to do this job right but one guy can't do this job and it always entails two or more especially when stepping. So with two guys that would make it 2.3 hours total which is a blistering speed to retrieve a mast, rig it, step it, tune it and connect it... I think Eherlihy got a decent price..
Gotta agree that isn't an outrageous price for (un)stepping a mast. Mine takes an hour with the crane and another hour to get everything right. That's 3 people for an hour and 2 for another 90 minuets. Standard labor rate where I do it is $45 an hour, I'm sure the crane operator is more. So 225 + the crane charges ~100. total 325.
Just got a quote here in CT for this coming winter season - $7/foot to unstep and store, and $5/foot to step.
Seems about in the ballpark for CT, as frustrating as that is!
Hey,
What does unstep / step include? Did they remove the sails and disconnect the electronics when they unstepped the mast? When the mast was stepped did they tune it and pin the rigging? Did they put the sails back on, etc?
The yard that I use is low cost, but I have to do everything - remove the sails, take the boom off, disconnect the electronics, etc. In the spring they install the mast and get the rig 'close' but I need to put the sails on, connect the electronics, tune the rig, etc.
So, your price may be good or it may be high depending on what the yard did.
Barry
No Mainsail the guys in the family run yard where I store my boat are good ole' boy Americans. No habla Espanol. They speak a very colloquial American dialect.
I must prep the boat the boat prior to unstepping. Boom and sails must be off. All halyards coiled etc. There are 2 yard guys and the crane operator. Total time about 1/2 hour. These guys are good and efficient. Mast off and on saw horses. Spreaders and masthead windex, antenna, and wind instrument off. Stretch wrap part of the mast to secure halyards and shrouds. Tractor uses sling to pick up mast and transport 200 yards to mast racks. Wham, bam, thank you ma'm.
I know these guys are a dying breed. They only store boats on cradles with the mast down so they end up stepping and unstepping the masts of all the boats in their yard. Hopefully they will be around for awhile before some developer scoops up their property. I have been with them for the last 15 years.
1 - 20 of 31 Posts
