Sail Construction – XCut, Radial or Hybrid?
There’s also the construction method to consider when buying a new sail. Is it best to buy a radial sail, a crosscut sail, or a hybrid? Each of these construction types reacts in different ways to produce the sail’s shape, which in turn determines how well the sail performs. But understand that what matters most is not usually the particular construction itself. Instead, it’s how well a sail of that type responds in a particular sailor’s hands. This means that experience with a certain kind of sail counts greatly. If a sailor is accustomed to crosscut sails, how they react, and their shape, I’d suggest that this person buy another crosscut. The same is true for a sailor accustomed to how a radial sail reacts. He or she should probably stay with radial construction. There’s typically little to be accomplished by switching to a different cut. The performance gains from a new sail that you already know how to use will typically be far greater than the potential gains from a new sail that you must learn how to handle. Also, sticking to what you have experience with can often reduce frustration and so add greatly to the fun of sailing.
