1 - 20 of 31 Posts
First String
We are planning to untie the lines in the fall of 2018.
As some of you know, I have purchased a 1981 C&C 30 MK 1 sloop. She was a mess but I got her for cheep. I have done a great deal of work and some up fit work, already. I need your help. I'm not sure how to proceed.
First I will give you a list of what I have done.
New dynemma life lines.
New 2gm20f Yanmar engine
New RACOR 500FG FUEL FILTER WATER SEPARATOR
New running rigging
New Hydrostatic PFDs
New Matrix AIS/GPS (GX2200)
New thru-hull's x 5
New LED steamer light
New LED cabin lights
New LED running lights
New LED anchor lights.
New AM/FM Radio
New Garmin Echo50s GPS
Rebuilt the Auto-helm 4000
ST50 wind direction and speed
ST50 depth and hull speed
All bulk heads checked
Chine plates inspected
Bottom cleaned and panted.
All cushions re-covered
Hillerange 3 burner, gimballed pressure alcohol stove "REBUILT" works great.
Boat tankage now
Starboard settee 18 water
V-birth 10 water
port holding 13 gal
Fuel 20 gal
What I am asking advise for on the following items that have not been addressed so for. Questions are what Brand, Size, Type, New, Used, Not needed ect.
Honda generator
Solar panels
wind generator
Water heater
Inverter
SSB with weather
EPIRB
Jack lines
cockpit cushions
Dodger
Dinghy
outboard motor
Monitor self-steering vane
windless anchor system
DVD player
refrigerator or build into the existing icebox a Yetti
Again what i'm looking for is advice on things that you think I need or don't need. Things you will need to know to help.
1) "It will be my wife and I"
2)"We will be harbor hopping up and down the eastern seaboard" we will end up in the Caribbean and Bahama's
3)"She will want to see movies in the evenings.
4) She does want to keep cool food for 4 to 5 days".
5) "She wants hot water".
Here is the other thing. She has asked me if I thing its going to be big enough? Is it too small? I told her is the maintenance and overall cost is a lot better on a 30 foot boat. But I screwed up and Chartered the 36 I down in the BVI this past spring. She thinks that boat was much better in size. Well the problem is that my boat is paid for and I don't have money for another larger boat in the budget. So the other question I don't want to ruin her wanting to sail with me because the boat is too small. Should I start looking and making a plan with a larger boat? I would hate to keep up-fitting this boat if she will never be happy on it. I am around 10 grand into this boat. All the other items if put into this boat, the boat will never be recouped if sold.
P.S She is a all hank on boat.
2 main sail's
114% reefing head sail
135% gen
155% gen
170% drifter
and a Asymmetrical in a sock.
All line's led to cockpit. Still a lot of work.
Thanks again for your advise.
LT
Here is the other thing. She has asked me if I thing its going to be big enough? Is it too small? I told her is the maintenance and overall cost is a lot better on a 30 foot boat. But I screwed up and Chartered the 36 I down in the BVI this past spring. She thinks that boat was much better in size...
Well, I sail a 30-footer, but only liveaboard for the duration of each cruise... When I'm alone, she suits me fine... But when I have company, things can get very tight, very quickly... :)
Only you can answer that question, of course - some couples seem to manage just fine on a boat of that size. But in my observation, they are a bit of a rarity out there today, and most more 'mature' couples are on boats considerably larger, at least closer to the mid-30's or so...
I STRONGLY suggest you try an extended shakedown aboard your present boat before making a final decision, or proceeding much further... Trust me, if the size of the boat is likely to be an issue, it won't take long for that problem to surface... :)
Stuff like a Honda generator will occupy a surprising amount of your storage space on such a boat. Mock up a cardboard box the size of a Honda 2000 (which everyone seems to think is essential these days) and stick it somewhere. Sorry, but you're gonna have to ditch some of those sails. A second mainsail, and that 155 genoa, is gonna eat up much of your precious storage space, as well. That alone is one of the best arguments for headsail furling on a cruising boat of that size. Whenever I remove my sails and stow them below, the space in which to LIVE on board is reduced dramatically...
Other things on your list strike me as perhaps a bit superfluous... I'm a huge proponent of windvanes, for example - but why do you feel you'd need one for "harbor hopping" down the coast, and thru the Bahamas to the Islands? Put your money into a good AP, that alone should be more than sufficient for such a trip...
But seriously, the size issue is the one you must address first, that's likely to be the one that makes, or breaks, such an endeavor...
Don't see mention of refrigeration.. either as 'should I' or 'I have'.. that bit of info will impact your electrical needs.
Read Jon's post over several times.. all good points.
Maybe book a week on a lake in a Catalina 22 to put your 30 footer back on the 'big' side comparison wise ;)
Solar, adequate batter bank, and good alternator/regulator combo should make a Honda superfluous.. and who wants to pack that gasoline around anyhow? Remember to add the volume of the jerry can to the mockup of the generator when it comes to finding storage.
That's the kind of thing you never want to hear from a woman ain't it ??
Yeah, once they've gone bigger they never look back, mine likes ultra leather interiors, too.
I don't think you can trick her into thinking it got bigger.
I don't see her getting any happier with it
Me too, refrigeration and running hot water required.
I sure would, but I've kept the same wife for 40 years and gotten different boats, much cheaper than the other way round.
First String
Discussion Starter · #6 ·
refrigerator or build into the existing icebox a Yetti ?
I could do like 2 more batteries for the house and charge them once in a while. We did that while we were in the BVI. We had good power while on the hook at night.
All good points
Premium Member
It sounds like your wife wasn't part of the restoration process? If I remember correctly, you've been at it for a while. Plenty of time to determine if the size is sufficient. If you don't have the money for a larger boat, I'm not sure what you can do other than hope she's willing to live with what you have. Also, I'd probably not count on getting what you put into the boat if you sell it. It might happen, but that's not the norm.
Bombay Explorer 44
Nix the Honda generator and wind generator, SSB, Water heater assuming it is using the engine as the heat source..
Aluminium arch with cross bar that allows the solar panels to be tilted. 300 watts + of solar. Good MPPT controller. Solar shower. Get the heavy duty thick plastic one if you can find it, else buy two of the thinner ones
Water is going to be a problem for you. I am a liveaboard and consider 150 galls water tankage to be the minimum. You have 28 gallons 3 days average use for two people. An awning with a water catchment system will help but in the Caribbean and Bahamas weeks without rain are not uncommon.
First String
Discussion Starter · #9 ·
Your right that it will never return my money. But not right on her being there. She has helped me a great deal on the refit and in-fact we are working on this project together. "I think that is fantastic" Its great when she brings things up that we need to do or think about. She is finely on board. We may be able to squeeze out some money for a larger boat if needed? But the first year we will use this one for sure. I just don't want to sink precious sailing kitty into getting a bigger boat and refitting it again. Thanks for your incite.
Administrator
Beneteau 393
You are going in 4 years time?
I wouldnt buy one more thing now.
Just go sailing and learn the important bit... How the boat works.
When not sailing save every dollar.
Mark
Premium Member
I'm glad she's been working with you. Don't forget that after you eventually buy the bigger boat, your expenses and maintenance costs are going way up. 30 is at some kind of weird fence where once you tip over into the other side, the costs aren't in small increments. I'm gathering that 40 is the same. I'm trying to keep our next boat, on which we'll spend most of each year living on, under that 40 mark.
For us, we'd rather have a slightly smaller boat with comfortable costs than a large boat with costs that make us afraid to spend any money for fear we won't have it when something on the boat breaks. Everyone approaches it differently, however. If you and your wife are communicating well with each other, you'll figure it out together.
First String
Discussion Starter · #13 ·
Great point here. I don't want to be boat poor. I want to be able to see the sights and visit the ports without being cash poor. If we size up it may put a cramp in that style. We are both very frugal and do well gathering cash she will be doing software from time to time. I will be doing transportation training as a consultant, to help fill the gap. I will be 55 she will be 54 when we leave so when we get tired in say 5 or 6 years into it we can just come home and retire.
We do communicate well, "my wife and I" So I think it will be fine. I just wanted some feedback of the up-size, don't up-size issue and if it would make it seam more like a home to up-fit with the for mentioned items. I want her to feel safe and comfortable and not want to go home.
I don't want to make her feel like she is on a camping trip.
:eek:
First String
Discussion Starter · #14 ·
So your 30 footer, does it seam too small?
What TQA said about solar panels and batteries and solar showers, although I'd carry at least 4 solar showers for 2 people (I Always like to have extras full on the deck and the cheap ones don't last too long). The dodger is also ESSENTIAL and a bimini and some way of fixing side curtains (it could be just an old bedsheet you tie up). When you get to the tropics you'll NEED sun protection if you're going to use your cockpit- and believe me, you will in the tropics! Otherwise, it looks good to go!
Premium Member
No. But we don't live on it and we're not on it for a week or so at a stretch without putting into a marina or anchoring. That's what the next boat is for. Our 30 footer is perfect for how and where we sail now. You may feel differently on your boat depending on your needs and lifestyle.
Also, I don't consider it camping because we choose to not live like that when on the boat. We eat well, we have what we need to keep us occupied when at anchor or after docking. After a long sail I love anchoring and watching the sunset with a glass of wine and a good meal. If I wanted to go camping I'd find the closest forest.
Size is a relative thing. I think if you set up your boat so you have basic needs and comforts met (a very personal choice), a small boat can be great. I cruise on a 35ft boat with my wife and 2 kids. For me, the size is great and I could go smaller if I cruised as a couple. For us, the essentials are a good bed, galley with counter space and everything to cook nice meals, fridge and comfortable seating at the salon table and in the cockpit. To this I'd also add good ventilation and sun protection in the cockpit. You could try making a list with your wife of what you both feel you really need on the boat and then see if you can modify or fit them in your current boat. I suspect if you can't meet these needs with your current boat you'll soon be looking for another. Hopefully Veja (Albin 27) and Greg and Jill (Norsea 27) will chime in with their views on living on a small boat. Both have made it work remarkably well.
Itgoshen, You and I are in the same (figurative) boat. Our schedule for Mexico is 2015 or 2016 and we are close together from the boat preparation standpoint (I really need to write down my projects list!) From a size standpoint, we are a little bigger and MrsB would love a 42 footer. But like you it is a case of go small, go now or go large and perhaps go never. I’m having to be a bit creative in making my boat “feel” bigger. You need to be a bit more creative. Jon Eisberg will do back flips, but I’m planning on jerry jugs and dinghy as “deck cargo”. I encourage you to do a lot of weekending and weekly trips to winnow out what is needed, nice to have or don’t bother. MrsB is fond of saying “the boat shrinks a foot every couple of days.” What you don’t have on your list is an upgraded electrical charging system. Hand in hand you will want to work out an energy budget as you will be surprised how many electrons you will consume each day at sea. We are forgoing the wind generator and monitor and instead doing solar and autohelm. We have refrigeration and hot water and heartily recommend both. An SSB is going to set you back a few kilo bucks and probably not needed where you’re going (MrsB insists that I remain connected so I’m going the Sailmail route.
Good food for thought! Let’s stay connected and continue to share thoughts and ideas.
1 - 20 of 31 Posts
