21 - 40 of 52 Posts
Bee:
I have a 1987 Merlin that I bought 3-1/2 years ago. The boat was in good shape when I bought it. The keel was loose, which was discovered at survey, and I had it rebedded. There was also minor blistering that showed up as well. I have ignored them, and they have not gotten worse. They weren't even visible on my last haul.
There is a crack on the starboard settee, which was apparently from the water tank being filled up to quickly. There also appears to be some settling of the liner, which is common for the boat.
The only apparent alterations to the boat was the traveler was moved aft, and I have a rigid boom vang.
Personally, I haven't done much other than add a Max Prop
CS36 Merlin - O Pato
Discussion Starter · #22 ·
Is your model a wing keel? fin? bulb?
Filling the water tank too quickly? Really? Never heard of that.
Do you have a photo of how the traveller is set up? Are you happy with its new position? Does it allow for a full enclosure under sail?
I'm considering the possibility of extending the steps in the companionway to create a less steep access. Any ideas?
It's a fin keel.
Filling the tank up seemed weird too. But I can see it happening. The tanks are huge (>120 Gallon for both of them) and the pipe for venting, and cross-connecting between the port and starboard tanks are only 1/2"... If you get impatient, because they are so large, you tend to want to crank up the water flow pretty high.... The hose mostly covers up the filler tube, and voila, you are pressurizing the tank.
I thought the story wasn't particularly believable at the time, but the surveyor agreed that could be the case. In my personal experience, I can see how it could happen, and I do not doubt the veracity of the previous owner
I will try and find a photo of the traveler. Not sure if I have one... I will check
Yes, the stairs are steep. I've grown comfortable with them over time. The grab rails are in a good spot, and as long as you go down facing the stairs, it's not too bad. My 82 year old father has learned to navigate them.
I have learned over several boat purchases to not mess with much until you've spent a few years with it. The wisdom of previous owners generally takes a while to become apparent.
Some pictures here
Kyrie 36 Photos by djodenda | Photobucket
Also, I forgot to mention that I had cracked stanchion bases. A common problem with the boat and a pain to fix.
Feel free to PM me, if you want to chat by phone.
Discussion Starter · #24 ·
Thanks for all this, David.
The '89 has the traveller placed right in front of the binnacle, which it appears to be where yours is now. The '90 model moved it to the coach roof.
Our boat (knock on wood) is a wing rather than fin keel. Not my favorite, but the previous owner installed forward-facing sonar to avoid grounding it.
The companionway steps are fully removable so I'm hoping I can modify them enough that the angle is just a little bit flatter.... either way I won't be making any changes in the first season. Learning the boat comes first.
The boat is in great shape but appears that it has not been sailed hard in a while. Hopefully we'll be able to open her up and see if the rumors about the Merlin's performance are true.
Cheers!
G
Yes.. that's where my traveler is...
She's fast. She likes some heel, keep weight forward downwind in light air.
She has a relatively wide groove... Play around until you find it.
And you owe us photos once you own her.
Does she have a windlass? Be curious to see the installation if so.
The short traveler is limiting. You can do quite a bit to control sail shape despite that using a rigid vang
Oh.. and I am having an adjustable backstay and babystay added to the boat ...
Old enough to know better
I thought the same thing until I looked at them. The traveller in the 89 is in the cockpit, but in the 90 they moved it to the coach roof. Also, the companionway in the 89 is a ladder, but in the 90 they extended it out into a stairway over the motor.
So far we've only seen the 89, but hoping to see the 90 as soon as the snow melts enough to get to it.... (gotta love the Ontario snow belt!)
Cheers!
G
Honestly those features would not sway me one way or the other. I personally would prefer cockpit traveler, and the stairway would be nice. Both could be changed if you really wanted to without too much work. I would look at the condition and if the keel/rig combo would suit your needs best. I would worry about the things that basically can't be changed like condition, rig and keel. For me if I found a better condition one I would deal with the location of the traveler or the stairs/ladder.
David.. babystay? Excessive pumping? or just mast shape measure?
I want to be able to remove the babystay when I am flying the spinnaker and/or flying a big genoa. Makes it hard to tack/gybe the chute.
The mast section is pretty stout, so I doubt I will be able to bend it much, but we shall see.
Never had any "pumping", but there is some annoying shaking/vibration when the mainsail is down, and there is some wind.
The rigger recommended a 6:1 block and tackle with a snap shackle at the bottom. So, we'll try that.
If I'm making a mistake, let me know quick. Work authorized, but not completed!
I will keep you posted.
Don't know about 'mistake', but having had a baby stay its a pretty major PITA gybing. Removable is good. Our last boat was masthead double inline spreaders and did the same vibrating esp in a crosswind. Other than the nuisance factor when on board we never worried about it, and there was never an issue under sail.. YMMV
Discussion Starter · #31 ·
Ok, price settled with owner. A few minor changes to the contract and we'll probably sign over the weekend.
I'm trying hard to stay calm but failing miserably. Considering getting a t-shirt that says "My Mast is Pumping", just because the phrase amuses me. Looking forward to the sea trial to see what kind of tacking angle she can manage.
My history with charter boats has not given me a great deal of expectation wrt to upwind performance. Hopefully, my own boat will be better.
David,
BEFORE you put said baby stay on your boat, come out for a sail with me, you will NOT want a BS afterwards, excepting if you only use a 110 or smaller, or a really light cloth like my drifter. Otherwise, YOU NEED a person forward to move a genoa larger than 130 or so around the baby stay while tacking, or it can and will get caught, and one will need to go forward to un catch the genoa.
I have thought of a removable BS for my boat, but two boats like mine have lost masts locally. Not sure if it is due to a lighter mast sizing, or some due to some wood under the mast base that starts to rot. OR a combo there of. An adjustable stay would be nice to give the mast a bit more bend. BUT< I can adjust my mast enough with the back stay.
MBee, Yes David is teh person I mentioned as did Faster earlier in the thread that has a Merlin. A good guy, despite moving his boat closer to the shore vs being across from me......not sure if his beer supply gets emptied as much any more.....but that is another story.
Marty
Marty:
The boat came with a babystay.. It's just connected to the deck with a turnbuckle.. I remove it when i have a big genoa up or am flying the chute.. The reasons I described above are why I want to be able to disconnect it easily.
Sorry that my beer supply is less convenient to you and your crew. Just stop by, though, and beverages will be provided.
David,
I did not realize you had a baby stay. So yes, a removable adjusting one would be nice to have. I've seen that done on another boat like mine. pretty slick actually. I recall a 4-1 being used. Then again, my mast is just a bit smaller than yours!:D
Marty
Dirt Free
The fracturing under the dinette/settee could have been caused by filling the starboard water tank too fast as the vent is a little small but not necessarily.
The same fractures can also be indicative of liner movement. if the fractures are confined to that area you may be all right. but you have to check a little further.
If you see the fractures at the settee, you then look for hairline fractures in the liner around the mast step, If you see fractures at the mast step you must next look for any sign of movement (downward) of the transverse frame member immediately aft of the mast then look along the bottom of the starboard saloon bulkhead for any sign of movement. If you see all four signs, you have liner movement.
I have attached a photo of very typical fractures at the dinette. If there are no fractures here then you have nothing to be concerned about.
Some of these boats have had shifting liners for years without any related failures, it's still a pretty strong boat but it's best if you are aware.
Also look at the trailing upper edge of the keel (lead) for filler or what looks sort of like like corrosion. There were some issues with poor lead alloy from Mars (the keel mfg.)
Thanks, BoatPoker...
Let me take some pictures... I'll post them.
I don't think I have the issues you described, but would be grateful for your input.
David
Ah HA! I too have a crack in the starboard settee. Prev. Owner said it was from a rather heavy crew member that got tossed in rough weather. Always thought that seemed odd. I suspect your reasoning is much more accurate!
And I too looked around for other hairline fractures; none to be found.
And I too plan to change over to a Max Prop this season. What size did you get; 17x14?
My boat also came w/ a baby stay; detachable and rigged w/ a 4:1 line.
My mainsheet had what I suspect was the original 4:1 setup; I've seen upgraded to a 6:1. Much easier on the back! And I'm considering putting a fine tune on that! Kept the original setup/sheet for backup as well as clipping on to the boom and using it as a hoist.
Photo of the windlass taken during the boat tour attached.
Contract changes have been approved by owner. We'll be signing tonight.... aided by a few very dry martinis.
Thank you for the picture.. Does the windlass protrude above the anchor hatch when it is closed?
And congratulations!
I will validate my Max Prop size and settings for you. You have the original Volvo 2003 engine, right?
My mainsheet is 6:1
21 - 40 of 52 Posts
