21 - 40 of 72 Posts
Discussion Starter · #21 ·
I disagree with the suggestion that NOAA's tidal current prediction are based strictly on modeling. I always believed that their multi-harmonic models were tweaked based on the hundreds of sensors that they have. And until someone provides proof to the contrary, that's what I'll continue to believe.
If there are discrepancies between Eldridge, Garmin, NOAA, or others, I assume that it's because they update their models based on different weighting factors. It's the classic case of separating "trends" from "noise," and it will cause differing predictions, much like the weather. Over time you may decide to have more confidence in one than the other.
Recommended reading: Tidal Current Predictions and Data
C&D Canal is a perfect example of hydraulic current.
The Delaware river exhibits something between progressive wave and standing wave, depending on location. Up near Philly where I sail most of the time, slack typically lags high and low tide by about an hour. The progressive wave model explains why you can have a flood current even after high tide has passed. If you've ever stood in waist deep water at the beach and felt a wave pass you, you've observed a progressive wave. Right after the wave passes, the water level drops, but the surface continues to push you in toward shore, while the strong undertoe starts to pull you out. Similar things happen in rivers - high tide is a wave that moves up the river, but its wavelength is so long that you can't really see it aside from observing the changing tide height along pilings, seawall, etc.
But if not...
BTW - the differences persist up and down the Delaware Bay, well outside the unique influences of the C&D canal.
I've posted a note with Garmins tech support team and will let folks know what they say. I suspect it'll be related to either their source data or their underlying model.
In any event, this is a classic example of why the prudent navigator will look to many sources, not just one. So carry a copy of Eldridge, print out NOAA, use Garmin and compare to what you see with your own eyes.
Timely discussion. I'm looking to sail around DelMarVa this year, and have been wondering how to time my passage through the C&D canal.
I'm looking to make a counter-clockwise trip, so I'll be hitting the C&D from the East, motoring West. James W. has been a big help with planning.
My engine runs very well, but I'm not interested in stressing it out. I hope I don't have to run at WOT for long periods in order to time the currents.
Bubble,
If you leave Cape May/ Cape Henlopen 2 hours before maximum ebb you will make it through the Canal to at least the Northeast/ Sassafras River riding the tide all the way. When are you thinking of doing this? ( date) I can give you more specific data.,
Just to add to the confusion a little.
I'm working on the planning for a possible June 2013 transit to NE including the C&D/Del Bay transit. The currents shown in Garmin BlueChart mobile and on the NOAA current tables don't match up.
Here's an example
June 1, 2013 for Reedy Pt, DE
Max flood Slack Max Ebb
Garmin 03:11 06:39 11:10
NOAA 04:49 07:35 11:49
Any ideas on what might cause the differences?
My reading from my Raymarine and confirmed by navionics on my I Pad are
From the Arnold Point shoal ( 10 miles s of Reedy on June 1 are)
slack maxebb slack max flood slack maxebb
6:02AM 10.12AM 12:30PM 3:15PM 6:43PM 10:43PM
From Finn Point 6 miles north of Reedy on June 1 are
6:17 AM 10:37AM 1:03PM 3:35PM 7:02PM 11:16PM
Confirms the Garmin Readings
If this was me taking the trip I would do th following. On May 31, the day before you will have the current through the Canal; in your favor from 9 AM till about 3:30 inthe afternoon. Go through the Canal and anchor behind Reedy and enjoy dinner till about 5 AM the next day. Or just continue through and get to Cape May harbor at 2 AM.
Setting your trip to be the fastest will be by using whatever technique to get to Reedy at 1 hour before the slack to ebb tide on the Delaware there which on June 1 looks like about 5:30 AM start time from Reedy.. Your best bet is to set your trip up by going through the Canal and anchoring at Reedy and leaving from there, 1 hour before slack tide before Ebb. This will enable you to reach Cape May Point before the current reverses. You will travel around 8 depending upon wind and sea conditions. Going South you get about 5.5 hours between Slack and the next incomming. Slack water at the Brandywine Shoal is about 10:00-10:15, (37 miles) Then another another 16 miles to Cape May Harbor. trip will take between 7-8 hours from reedy Anchorage to Cape may Harbo. If you leave at 5:30 AM you be in Cape May by 1:30 PM
I see you ahve a 42 footer so I am assuming power is no big deal.
There are two
But if not...
I've reached almost exactly the same timetable you've laid out, Chef. Sneak out of work on Friday (work by phone) and meander up the Bay, through the C&D to behind Reedy Island. Then catch the dawn tide shift to ride it through the Delaware.
I've done the Delaware at night and it's not my favorite. Although it'll be a waxing 1/2 moon around the beginning of June.
Yeah - I'm not too worried about powering hard if we need to. In fact, I would be OK bucking the current for a slow ride through the Canal at night if need be to catch the ride down the Delaware at first light.
The huge unknown, of course, is the wind. And no way to know that until June comes. I'm plotting out the departure times for all the weekends in June figuring that one of them will offer a good weather window.
Good show,
Weve done this trip about 40 times...The most boring part of heading north. Taking the morning tide usually means calm water in the AM down in the Bay before the onshore breeze starts cranking in and builds up the chop.
The canals not bad at night, but the Delaware is not my favorite as there can be floating objects
Where are you going in NE?. brokersailor is headed nborth in mid June I think. Where do you sail from. Are you stopping in Cape May?
We wont be heading up till mid August as we like no crowds and theres no wind here in the Chessie usually.
dave
Discussion Starter · #27 ·
Even though I had 10-15 knots out of the ESE, I motorsailed the most of the way up the Delaware Bay and Delaware River to the C&D, so I could make the 8 knots over the ground necessary to ride the current for 14 hours. The difference was the boat never slowed down, so the P28 would hit 8.5 knots surfing down the front of the chop and not slow down to 5 knots on the back.
You can hear the engine running (and my rudder clicking) in the video, while I sail at maximum speed: Glorious day on the Delaware Bay... - YouTube
Does the sun ever shine down there? Every video I've seen has dark gray or black clouds and/or small craft advisories playing in the background. :(
But if not...
Just can't get enough, huh? Tentative plans are early to mid-June. Don't know brokesailor - will have to look him up.
We live in Annapolis, but keep the boat at Herrington North. Have done the round trip once as a family. But also the North-then-West one way a couple times. Last time we stopped in Cape May for a night's sleep, but we had 3 weeks for the trip. This time we may be limited to 2 weeks so am considering not stopping. Our air draft (53') is cutting it close for the Cape May Canal anyway. If we have to go around, then I'm inclined to just keep going for Block.
Funny story - when we came through the canal at night, I was asleep below and my wife was on watch. She yelled that a big ship with a strange light configuration - 2 whites in a horizontal line - was heading right towards us really, really fast! Turned out to be a truck driving on the access road next to the canal. But a serious enough adrenaline shot that she was very alert the rest of her watch.
Discussion Starter · #29 · (Edited)
...I've posted a note with Garmins tech support team and will let folks know what they say. I suspect it'll be related to either their source data or their underlying model...
Please let us know what they say - it will be interesting to see what they are willing to tell you. I have the Bluechart mobile on an iPad at home, so I just looked at its current predictions. It's still so new that it hasn't become my go-to device (I still use OpenCPN for mostly everything), so I'm just learning.
NOAA's multi-harmonic model is very sophisticated (I read somewhere that it uses over 12 harmonics), and the source code can be purchased from them for a fee. Despite what some may believe, it is based on what I believe to be the world's most extensive collection of historical data for US waters. That historical data is available openly, and companies like Garmin almost certainly use the same data in developing their own models.
Unfortunately, much of the tidal modeling that used to be freely available for use has been tied up by private companies (like Garmin) making intellectual property claims, so unfortunately there will never be a convergence to a "single best" prediction (unless you believe that nobody can top NOAA's brainpower, which unfortunately has become as much an ideological question as a scientific one). But it's almost certain that everyone uses the same NOAA data (though different companies may update their models for recent data more or less frequently). So the main difference is probably the model that's used to fit the data and make future predictions. There are some interesting comments on the difficulties of doing this here on the XTide support page.
I took a quick look at Garmin's current predictions on the iPad, and the waveforms look very sinusoidal, which is a signal that they use fewer harmonics in their predictions than others. So in general, it may be less precise than models with more harmonics, although there is a valid question of how precise anybody's prediction can be because the effects of rain, wind, and other less predictable effects would limit the precision of any model, no matter how sophisticated. At some point your prediction becomes far more precise than Mother Nature is willing to cooperate with. ;)
FYI, OpenCPN has some very complex wave shapes in both their tide and current predictions, which is a sign that their predictions (based on the XTide algorithms, but with significant manual tweaking) incorporate a lot more harmonics than Garmin's. Once again, whether that actually leads to a better prediction is up for debate.
In addition to the XTide support site, there is also some very interesting background information on tide/current predictions on NOAA's site here. For instance, the lower harmonics are such a low frequency that you need 18.6 years of tidal data to make a reliable prediction. This is not something that you can do by flipping through a few pages of data and manually fitting a spline curve!
By the way, click here for a fascinating rant on how privatization and "un-public-domaining" of tidal data has made it virtually impossible for anyone to offer free tidal predictions in Europe.
please let us know what they say - it will be interesting to see what they are willing to tell you. I have the bluechart mobile on an ipad at home, so i just looked at its current predictions. It's still so new that it hasn't become my go-to device (i still use opencpn for mostly everything), so i'm just learning.
Noaa's multi-harmonic model is very sophisticated (i read somewhere that it uses over 12 harmonics), and the source code can be purchased from them for a fee. Despite what some may believe, it is based on what i believe to be the world's most extensive collection of historical data for us waters. That historical data is available openly, and companies like garmin almost certainly use the same data in developing their own models.
Unfortunately, much of the tidal modeling that used to be freely available for use has been tied up by private companies (like garmin) making intellectual property claims, so unfortunately there will never be a convergence to a "single best" prediction (unless you believe that nobody can top noaa's brainpower, which unfortunately has become as much an ideological question as a scientific one). But it's almost certain that everyone uses the same noaa data (though different companies may update their models for recent data more or less frequently). So the main difference is probably the model that's used to fit the data and make future predictions. There are some interesting comments on the difficulties of doing this here on the xtide support page.
I took a quick look at garmin's current predictions on the ipad, and the waveforms look very sinusoidal, which is a signal that they use fewer harmonics in their predictions than others. So in general, it may be less precise than models with more harmonics, although there is a valid question of how precise anybody's prediction can be because the effects of rain, wind, and other less predictable effects would limit the precision of any model, no matter how sophisticated. At some point your prediction becomes far more precise than mother nature is willing to cooperate with. ;)
fyi, opencpn has some very complex wave shapes in both their tide and current predictions, which is a sign that their predictions (based on the xtide algorithms, but with significant manual tweaking) incorporate a lot more harmonics than garmin's. Once again, whether that actually leads to a better prediction is up for debate.
In addition to the xtide support site, there is also some very interesting background information on tide/current predictions on noaa's site here. For instance, the lower harmonics are such a low frequency that you need 18.6 years of tidal data to make a reliable prediction. This is not something that you can do by flipping through a few pages of data and manually fitting a spline curve!
tmi:)
We are also 53 ft and have never had trouble in the Cape May Canal. Just make sure its not a full moon and high tide.
We go north every year for at least 21/2 to 3 weeks, We do stop at Utsches before heading up the coast.
I have been in the C&C Canal once at night when we saw a big ship ( lights and radar) and pulled to the side. There was a 35 ft sailboiat following us a half mile back who stayed in the center. The freighter blew his horn at 10PM right next to us and we almost jumped out of the boat.
I have seen the lights of truck and they are confusing although those yellow vapor arc lights of the canal are bright.
dave
Discussion Starter · #32 ·
Discussion Starter · #33 ·
...I have seen the lights of truck and they are confusing...
Maybe that's what happened to this guy. My buddy at work lives about a quarter mile away and the commotion woke him up.
He looks like he lost an engoine and drifted over, No real damage from striking the side hard,
Discussion Starter · #35 ·
From my friend who lived nearby: He hit it at high speed (est. 25-30 kts). Witnesses said there was nobody at the helm - apparently he put on the autopilot and went below.
My friend went over to Summit North the next day to see the boat up on the hard. Huge hole in the hull.
Discussion Starter · #37 ·
On Autopilot in the C&D!?! You have to kidding me...:confused: I've seen pilot-less power boats on the Chester..but the C&D..?
[hijack]That was the speculation - not sure what the investigation revealed. There were witnesses who said they saw the boat speeding past, and could see nobody in the cockpit. But is was dark out (aside from the Canal's amber lights).
Obviously I was just joking about the guy getting confused by headlights along the service road.[/hijack]
Dark out going top speed of 30 in the Canal on autopilot.....and thats all the damage from hitting the rocks. I have seen 3 side of the boat in pictures and it looks like nothing. 30 mph and it only goes a little on the rocks
Something wrong with these facts.
Discussion Starter · #39 ·
Since my friend pieced together the story from informal comments he heard from bystanders at the scene, it is very possible that facts are wrong or exaggerated.
However, do realize that the guy did not run head-on into the rocks. He veered over gradually into them.
My friend personally saw that boat on the hard at Summit North, and there was extensive damage to the part of the hull that you can't see in the pictures (because it's lying on the rocks). They had to attach a large sheet to patch over the hole so the boat could be towed without sinking. That's one of the reasons they had to wait until the next day to refloat.
At 30 mph hitting a jagged surface like rocks you dont exactly side over them I wouldnt think. And you wouldnt just puncture a hole in the hull.
I have see a PB sideswipe a bouy at 20 knots and there was extensive FG damage. Sounds like your friend got an embellished story. :):)
The greatest danger we have found in the Canal are the go fast boats with no speed limit and flat water. They fly aorund the corners. Least you can usually here them coming and they dont throw wakes.
21 - 40 of 72 Posts
