Greetings, just bought a 2008 Hanse 470 with a mix of unique tech/networking.
The previous owner had 2 Nav system (1) an Unbuto based Open CPN system running on an old Intel I3 box with a VGA monitor display (2) a Triton B&G chartplotter on a NMEA 2000 backbone.
Hopefully the image i hoped to attach is visible,
If you can see the image, you will note that (1) there is a Rasberry hub in the Middle with connection to
M goal is to get as close to a functioning NMEA 2000 backbone, Get rid of the 7 year old slow Unbutuu box out of the way, and use the existing AutoPilot and AIS GPS for another season.
Question 1: can anyone explain what the Rasberry does? Is it multiplexing,
Question 2: will this work better - run everything off of the B&G chart pllotter and forget about the Unbuto box.
(a) connect the AutoPilot to the NMEA 2K backbone with a dedicated NMEA 2k <-> 1083 converter box
(b) connect the AIS to the network with a dedicated NMEA 2k <-> 1083 converter box
(c) buy a high accuracy GPS antennae and connect it directly to the NMEA 20 Network.
Question 3: Why is everything connected to a wifi router - specifically the radar?
Question 4: why is the radar connected to the wifi router and can it connect directly to the NMEA 2k backbone?
- an older Garmin 1083 Auto-Pilot,
- a USB based older GPS Puck,
- AIS feed,
- NMEA 1083 <-> 2k converter,
