1 - 20 of 60 Posts
I don't discuss my member
I plan to start this task next month on my boat. I'll be using balsa core and wanted to get some opinions on bedding hardware and using a liner as outlined in another post here on sailnet. I just want to make sure that a skim layer of FG is not required on the inside for strength. I plan to do the re-core from the inside leaving the outter decks untouched. (I know, I know).
I'll keep updating this post with pictures and progress. Hopefully I can have the repair done with 100sq ft of balsa, and minimal down time.
Here are the steps I have outlined
1. drop the mast and remove hardware
2. strip insides of anything important, vests, gear, etc.
3. start from the companionway and cut sections of deck out working my up to the bow.
4. plug all hardware holes to keep out rainwater, and allow a week to dry.
5. begin cutting and expoxying new balsa in place, same order as it was removed.
6. epoxy over all exposed balsa to seal it. Let it cure.
7. drill new holes and install hardware.
8. cut and install liner.
9. put the stick up.
WAAAY easier said than done. I'm not looking forward to this.
Cored decks, like cored doors get their stiffness from the outside laminate layers, not layer.
You'll want to put at least one layer of FG over the core.
Imagine a door to your home with just the outer face and some cardboard waffles on the back. Imagine how fast it would warp out of true.
Another point, check your epoxy's curing temp's for min/max. Gooey don't work.
Senior Mumble
How do you intend to hold the balsa in place from underneath while the epoxy cures? I experienced sagging. Some sort of bracing is necessary. As chucklesR said, you absolutely do need the inside layer of fiberglass. You can save the inside skin, grind away any rotten balsa stuck to it and glue it back in place. Then you'd only need to glass the seams. But holding the layers in place will be your biggest challenge. As steated in the earlier threads, the one lesson, main lesson, I painfully learned was: do it from the top. I know, you know. Once the epoxy was applied, I didn't want to stop and grind it all away after I figured out how to brace, so I ended up putting screws from the top into my core to hold it in place after the sagging couldn't be stopped due to insufficient bracing from below. That left me with holes to fill from above anyway. Think it through. Folks have been successful doing this from below, but not me.
Good luck.
Super Moderator
You're forgetting a very important part of repair from the bottom GRAVITY! Use vacuum bagging!!! What ever the interior skin was made of lamination wise I should be put back with the same schedule.
I can assure you that without vacuum bagging this job will be harder, and come out with more gravity voids than doing it from above and repainting the decks. You make it sound so easy and I wish you luck!!
Midwest Puddle Pirate
I agree with Chuck. The balsa core causes the deck to have structure much like an I-beam. Without the interior fiberglass, you've got nothing.
What has been done with success, but more work initially, is to save the interior fiberglass as a panel. Carefully cut around the area you wish to cut out, and very carefully remove the fiberglass by cutting the core out. Then you can grind off any remaining core material from your panel. Then you can replace the core. To reinstall the panel, wet out the balsa core, the apply thickened epoxy to the panel. Prop the panel in place making sure it has good adhesion all the way across. Then fix the cut lines and you're done.
Or you can do what I did. Hold a 50 x 60 inch piece of dripping wet 18-2 biax over your head for about an hour.
Super Moderator
Good luck.
I believe folks "think" they have been successful. I have had the opportunity on a number of occasions to either dig into this work myself from above or have seen it in the shop and can assure you they were not nearly as successful as they thought they were..
I tried vacuum bagging mine, with no luck. I couldn't get a good seal on the stupid thing. So I used a piece of light plywood (3/16 if I remember) and braced it in multiple places. Yes it sucked.
Discussion Starter · #9 ·
How large an area are you talking about? You mention in the post going from the companionway forward. I can't fathom doing that much core work from underneath.
All of it. :D
There is no paint on the deck now, just gelcoat and I'd like to keep it that way, the outter shell is in good condition and I really don't want to hack it up if I can avoid it. The inside liner is cracking severly and coming apart, mildewed and rotting.
I guess my other question (which I've asked on a Merit site) was the thickness of the core. It looks to me like 3/8" plywood, I'm assuming I could use 3/8" end grain balsa to replace this correct?
jbondy, I plan to use adjustable "hood props" that some mechanics use. Basically a telescoping pole that can be locked into place. If those don't turn out to be cost effective, then wooden dowels cut to length will have to do.
Discussion Starter · #11 · (Edited)
I can see you getting the core in place somewhat BUT i am not seeing the glass work as being that easy :eek:
I also see that as being my biggest headache. I'm open to suggestions, I don't believe theres FG on the inside as it is. Looks more like a thick coating of something else. I don't see any fibers in it even where its broken apart.
Edit: I'm planning on using Contourkore as the core material.
Start with a small area, just to give yourself a feel for the pleasure, and accomplishment of undertaking of such a gratifying job. Kind of work the kinks out. Then when you are thoroughly coated, covered and bonded to your mess, you can revel in you good fortune that you didn't try the whole thing in one shot. Take lots of before, during, and after photos. Hey a video would be great! Lord know we all need a good laugh! (you poor bugger)
I thought you were planning to circumnavigate Delmarva this coming spring!? :D :D :D
More seriously, would it be at all possible to unbolt the deck and flip it over to do this work? It sounds daunting, but I think it would save you a ton of time in the long run and also yield much better results.
On my J24 hull core sample from the knot meter the OUTER SKIN is thin and the inner SKIN is about double the thickness
I am unsure how the deck is layed up in terms of skin thickness
Discussion Starter · #15 ·
lol, exactly why I don't want a squishy deck between me and the atlantic. ;) And besides, I tight deadline is always good motivation. :laugher
From what I've read, you need to haul the boat for "deck removal", and also make a jig so the FG deck shell doesn't twist in odd directions while you're repairing it. It's also considered to be extremely hard to refit the deck to the hull. Most of the time one or the other has tweaked while they were apart, and now doesn't fit properly.
...from what I've read, you need to haul the boat for "deck removal", and also make a jig so the FG deck shell doesn't twist in odd directions while you're repairing it. It's also considered to be extremely hard to refit the deck to the hull. Most of the time one or the other has tweaked while they were apart, and now doesn't fit properly.
Okay, for some reason I thought you had your boat on a trailer/cradle in your driveway. Regardless, you make some valid points about keeping the hull and deck in the proper shape. I think it could be done (with the boat hauled, of course), but no doubt it would be a major undertaking.
Then again, what you are about to embark on is no picnic.:eek: I would really think hard on the advice from Mainesail and others who've tried or seen this tried.
P.S. Also, you might touch base with ArtbyJody. He was facing some serious work on his Catalina 27 but eventually came to a different solution.
I'm still trying to figure out why you are wanting to do twice the work, just to save a can of paint. Are you afraid the deck will look so much better than the topsides that you'll have to paint the whole boat?
Seriously, ZZ - forget doing it from the inside if it's that extensive. You can ruin the boat.
You'll never get a properly bonded core and deck. This can work for smaller areas, but if you're doing a majority of the boat...forget it.
You need to cut from the top - do it in sections - foredeck, each sidedeck, cabin top, etc.
1 - 20 of 60 Posts
