Are you SURE that the measurements are from wet core? I think there are lots of people (including surveyors) out there who don't know how to properly use a moisture meter. Moisture meters work by measuring the resistance in electromagnetic field and there is many ways which they can be fooled. A high reading may mean that the deck section is slightly thicker where you are measuring or that the core is not the same material in the area you are comparing to your reference location. In many cases the decks in older boats are not 100% balsa core. Some areas may be reinforced with marine grade plywood for added crush strength at winch mounting locations and deck tracks. It is important to understand that differences in density (including areas where bulkheads, electrical wires and backing plates meet the deck) can cause the meter to read "high" moisture when there really is no moisture problem.
While I can't say for sure if the deck is wet in your situation, I don't like the looks of the cracking that are clearly visible. But this might be common on the Cal's; or it could be a problem that could go back to wet core.
Tapping out the decks and looking for voids would also help determine if your moisture readings are valid.
