1 - 6 of 6 Posts
My Sabre 28 has a bit of delamination near the bottom of the compression post beneath the cabin sole -- not a structural issue, the surveyor assures me, but it does cause the bilge cover to 'wobble' in that area.
Any suggestions on how to best repair without cutting into the cabin sole? The teak and holly of the sole, itself, looks good and is dry -- it's just this support piece of plywood, underneath.
A few years ago, Ed Gawarecki posted the following regarding a Sabre 30:
"Nice sailing boat, the only area of particular note to check would be
the support piece under the cabin sole below the compression post that
supports the mast. There have been problems with delamination of this
part. If delaminated, repairs would need to be done, but not that big
of a deal."
Sounds like what I'm dealing with -- and I'd love to know how to make this 'not that big of a deal!'
Thanks,
Dr. C.
Ornery Cuss
Ive recently torn apart the whole mess and will try to post pictures for you. Its no small job but you'll find that the stringer "block" under the compression post is just some screwed together plywood and is rather suspect anyways so is a nice thing as far as piece of mind goes to take care of. Mine was a totally mush ball. So was the sole under all the filler they put on it. I replaced the compression post support block with a solid piece of 4x6 douglas fir, new plywood floor and now finished sole on top. My "teak and holly" which is really some sort of teak veneer over a polyester filler (about an eighth of an inch thick when new) was also dry and not much hinted at the rotten mess below. Not a warning to scare you but these boats were built with plywood that was not sealed so the sole is totally open to moisture intrusion. If a small section were cut away you could likely replace just the problem areas under the rig but would probably want to opt for a complete new teak and holly type covering so as to look uniform. Heres a few links to the whole ordeal: I was doing the whole boat over anyways so dont be alarmed at the amount of stuff being taken apart in pics. The boat now has all new stringers, sole, bulkheads, galley, berths, stove, some wiring and engine upgrades. Been a fun project so far. Enough for one winter though, time to go sailin' Im here if you have questions. Cheers. Brendan.
Before:
http://i268.photobucket.com/albums/jj33/u_b1walsh/P1010121.jpg
During:
http://i268.photobucket.com/albums/jj33/u_b1walsh/P1010125.jpg
Soggy Post Block:
http://i268.photobucket.com/albums/jj33/u_b1walsh/P1010157.jpg
New Block:
http://i268.photobucket.com/albums/jj33/u_b1walsh/P1010152.jpg
New Stringers:
http://i268.photobucket.com/albums/jj33/u_b1walsh/P1010151.jpg
New Sole glassed
in:http://i268.photobucket.com/albums/jj33/u_b1walsh/P1010062.jpg
Dr C
does your surveyor have experience with Sabre in particular...what you have described is a known issue with many Sabres. On my 38, the laminated block was replaced with an epoxy coated piece of hardwood, and a steel plate on top. YOu will need to make sure that this piece is correctly made, installed and sealed, else it will re-appear. The 28's are very similar, smaller.
If this has been completed correctly, then you merely need to repair/replace the sole itself. Once the backing has been wet and not dried correctly, you almost need to replace (it is easier) SOme replace with synthetic teak, others use an epoxy coated marine plywood and attach veneer, teak, holly, cherry, mahogany, etc and then finish. To match to the existing curved sole, that is likely 20+ years old, you will need to find a true craftsman, boat carpenter and someone who knows Sabre...
All the best..btw, the solution is to seal the mast step/partners, open or add limber holes to the sump where the step sits and make sure that any leaks are corrected...
dave
Fix for the wobble
If the bilge cover is the only problem, try this. Cut small posts of treated lumber to fit snugly between the lip on which the cover rests and the floor of the bilge. Fasten them with screws tdown hrough the lip into the post. The posts will take the load off the lip, and will stabilize the bilge cover.
But pay attention to the more serious issues raised in the other posts.
Thanks for your post riphonda!
Just about to attempt this myself -- what I found under the compression post most closely resembled compost ... guessing it's been there about 10 years. :(
After investigating marine ply laminated into a block, fiberglass layup to height and even concrete (!), I'm leaning towards using a chunk of "live oak" for the replacement support. I'll post pictures as I go through it.
Nice to see that nasty sole/flooring _can_ be removed! ;-)
Cheers!
cheap ugg boots
discount ugg boots
ugg outlet
ugg boots clearance
ugg boots sale
kids ugg boots
ugg boots outlet
classic tall ugg boots
discount ugg boots
wholesale ugg boots
genuine ugg boots
The UGG® Australia story began in 1978 when a surfer by the name of Brian Smith needed a way to keep his feet warm between waves and the UGG Classic was born. Crafted from Merino grade A sheepskin, the classic surf boot is lightweight and perfect for walking on sand. The idea caught on and today UGG® boots have become a phenomenon.
UGG Australia is a brand that is all about luxury and comfort for everyday life. Only the finest quality materials are used to create UGG boots and UGG shoes. UGG® Australia is the largest distributor of sheepskin footwear. Every shoe will feel great from the moment you put it on, year after year.
The UGG Australia kids collection flaunts the same style and comfort offered in the adult line. From slippers to boots to casual footwear, UGG Australia Kids will pamper the feet of your infant, toddler or big kid. Your little one will love the feeling of sheepskin as much as you do.
Although made famous by its boots, UGG Australia has extended their product line to include stylish yet elegant clothing for both adults and kids. UGG Australia has designed a vast collection of gloves,Classic Short UGG Boots, scarves,Ugg Boots, hats, and UGG coats that will wrap you in warmth against the cold winter months. When the weather heats up and warm breezes blow, you can now enjoy cute dresses, wraps and lightweight hats.
Now you can accessorize your favorite outfit with not only UGG footwear but a fabulous bag too. You can travel with a tote, shop with a cross-body messenger or paint the town red with a chic clutch or wristlet. All UGG handbags are crafted with the same attention to detail that has made them the premier brand they are today.
cheap ugg boots sale
cheap uggs
ugg boots sale
cheap kids ugg boots
ugg boots sale
uggs on sale
cheap ugg boots
discount uggs
uggs outlet
cheap uggs online
cheap uggs outlet
ugg boots uggs outlet store
uggs outlet
discount uggs
cheap uggs
uggs boots on sale
uggs factory outlet
uggs outlet store
ugg boots outlet
uggs on sale
uggs for kids
1 - 6 of 6 Posts
