1 - 2 of 2 Posts
Barquito
Discussion Starter #1
I am going to run some RydLyme through my raw water, and freshwater loops. Is there any reason I shouldn't use a small bilge pump to circulate the fluid? Is there a problem with too much flow?
What size pump are you considering? I use a small bilge pump, 500 GPH or so. I circulate it for a few hrs. There is a lot of nasty crap that comes out, so I have a foam filter on the intake side of the pump to keep the large bits out of the impeller.
1 - 2 of 2 Posts
