1 - 11 of 11 Posts
Love my Dickinson diesel heater. Wish there was less heat going up the chimny.
I made a booster from a piece of house ductwork, a stove pipe cap and a computer fan. Cup square hole in endcap and riveted fan to the cap. Hose clamp cut in half and riveted to duct.
I wraped some copper tubing around the stack for more surface area.
$ 30 invested and it works great. I can turn the booster 180 deg to heat either main cabin or V-berth. Little noisy.
Since I needed to clean the stove out today, I wired a two position switch to slow down the fan with the built in rheostat. Love it. Absolutely quiet on low.
Easy to remove for the two weeks of summer....
Neal
I just googled Nanaimo , it's 11degrees , I hope you have that thing cranked full blast !
Hey, here is a thought why don't you come down here to SoCal. and we will turn that set up into a still ?
11 degrees Celsius is about 52 degrees F. Southern Vancouver Island is often the warmest part of Canada in the winter.
· islander bahama 24
Cool idea and in the long run it will save you fuel 11 deg heck at that warm I consider turning the heater off or at least down as low as it will go in fact just shut the pellet stove off its almost 14°c or 57.3°f here in Tacoma wa
A Bora-type cabin heater directed to blow on the heater can do just as well, and is free if the location works. Just be careful that the fan does not create a draft.
Personally, I like a cold sleeping cabin; 50F is about right. I sleep better.
Not finished at the time of the photo. The curtains had to go because they were ugly, and the stack is not fully secured.
1 - 11 of 11 Posts
