- Reaction score
- 5
Hi all.
My sailboat has a Westerbeke 42B4 diesel engine.
It starts normally, and can run for hours at cruising speed. Later, when I need to wait for as bridge opening, I would witch between neutral and idle speed for some time. Then, when bridge opens, I would press ahead, but the RPMs wild slowly drop and engine stops. Even at full throttle. Sometimes RPM would fluctuate without giving full power.
Restarting the engine sometime fixes the problem temporarily, until the next bridge...
Very frustrating.
More info:
- In neutral, the RPMs are holding fine, the problem is when engine is engaged.
- Fuel filters are freshly replaced and clean
- Tightened all fuel line clamps, etc. - fuel and air leaks are unlikely.
- Prop is clean
Any suggestions will be greatly appreciated.
Thanks.
Very frustrating.
More info:
- Prop is clean
Thanks.
