I have a similar size dinghy (just under 8' Dyer Dhow Midget) and sailboat (almost 29' Pearson 28-2).
I made a lifting bridle for our dinghy that connects to the bow and stern up fairly high. It is a 2 point bridle so that we can rotate it upside down.
We use the spinnaker halyard on a winch to lift the dinghy. Sometimes to make it really easy we first hoist a block and tackle on the spin halyard, then use that to lift the dinghy. I think that the block and tackle would also make it easier to do solo, because I can do all of the lifting and dinghy management from the foredeck.
Typically one of us is on the lifting line and the other is managing the dinghy to keep it from hitting the big boat. As we get it up over the life lines we swing it above the foredeck, flip it over (remember the 2-point lifting bridle) and place it on 3 throwable cushions. It is tied down with those as padding to keep the dinghy from rubbing on the foredeck. I tie it down to the two bow cleats and to two sliding eyes mounted forward on the genoa rails. The back of the dinghy is right up against the mast.
I have an idea that I'm going to try this year which I think will make it even easier. I'm adding an additional set of shackles to the front of the lifelines which will allow me to unclip them from the bow pulpit. I can then put down a piece of carpet along the toerail and pull the dinghy up along there. We won't have to raise the dinghy as far or work as hard to keep it off of the boat. I think that this should allow me to do the whole thing myself.
Our dinghy is the perfect size for our sailboat. There is plenty of room for foredeck access to work with sails. It is short enough that I can easily get it out of the way of the anchor locker so that we can anchor while the dinghy is onboard.
I don't know if your dinghy has a mast and sails, but ours does. I keep the centerboard and rudder for that in the laz. The mast and boom are tied together and stored under the spinnaker pole along the starboard stanchions. All of this can fit under the dinghy, but somehow I find it easier to store them elsewhere. We also use take-apart oars which we can store in the dinghy or inside the laz.
