1 - 2 of 2 Posts
Good evening,
We're looking for a direkt alternator replacement, identical case size, for our Perkins 4-108, without having to go through the trouble of adjusting alternator brackets or custom welding. With a new AGM battery bank of 600 amps, a high output alternator of 150 amp would be ideal, and a smart regulator is planned for. Any thoughts on brand and model that could fit this bill?
Thanks,
Jolanda
Pearson 385
It's unlikely, I believe, that you will get a small-frame alternator with that kind of output and it is likely that the original alt from the Perky is a small-frame unit. All supposition on my part because I don't have a Perky.
The alternators that deliver 150A are generally large-frame units such as Balmar and they will not ordinarily fit the standard bracketry on an engine.
I had my original small-frame alt (35A) from my Yanmar refurbished and was told that the best output they could give me would be 85A which is what I have mounted on the engine now.
Hope this is of some use.
1 - 2 of 2 Posts
