sounds like a good idea there in the last post. I only used a tiller extension on my prindle19 cat and could not do without it. when you are hiked out on a trapezze there is no other way. Now, on the ericson26 thought about it and thoutht it would be usefull never did it. When I needed to take a pee or get a drink I just used a jib sheet and wrapped around the tiller and to both cleats on the side to keep her staight for a moment. You must balance your sails and even then she goes where she wants
I thought if I had a tiller extension I could steer from cabin. I think you should get one from a small cat and fit it yourself. Check craigslist or ebay and you will find one cheap. Just be aware that it's a pain when not using it and on that sweet tiller you made you have to drill holes, I really hate to drill holes. However, sometimes it has to be done.
