1 - 7 of 7 Posts
Discussion Starter #1
I have just bought a Santana22 of unknown age (suspect 23 years old).
I've heard the keel bolts need replacing on this every 30 years.
Can anyone tell me if these keel bolts look like they need replacing?
Corsair 24
looks like some nuts are almost gone(cant tell from the angle though)
Im redoing my keel hull joint on my islander 36 and all the NUTS look awesome, there is water in the bilge however......I kind of pay attention to the nuts more than the little remainding stud....
however if you want to be sure use some penetrating oil on the best looking bolt and nut...and try to move it...if you can retorque(with keel supported a bit) then they should be fine
I would at least replace all questionable NUTS and the ospho them or paint them
Bombay Explorer 44
You can not tell the condition of the keel boats without removing them. Depending on how they are attached to the keel this may mean dropping the keel.
A bolt can have a good threaded portion and be badly corroded where it passes through the hull.
Corsair 24
true...
but...
Keelbolts need replacing every thirty years only if they were installed on Fridays. If they were installed on Mondays, you can wait thirty three years and one month. Tuesday installations last for thirty five years and six weeks. For Wednesdays add 15 months to Tuesdays. Thursday keelboat installations are only good for twelve years. Replacement also depends upon how the boat has been used (or misused). Boats that have been repeatedly run aground are likely to have more keelbolt issues. Boats that have had bilgewater sitting in them for long periods are more likely to have problems. especially if the bilgewater has been allowed to freeze repeatedly. The visible ends of the keelbolts - the threads and their nuts - do not necessarily indicate the condition of what's below the keelson and inside the keel itself, as noted above. If water has gotten into the keel/hull joint, or entered from the top through the bilge, who knows what sort of corrosion could have happened. Without pulling the bolts (not easy) there's no way to be sure. If the bolts look good and the keel doesnt' seem to be moving, there probably isnt much to worry
about.
Keelbolts need replacing every thirty years only if they were installed on Fridays. If they were installed on Mondays, you can wait thirty three years and one month. Tuesday installations last for thirty five years and six weeks. For Wednesdays add 15 months to Tuesdays. Thursday keelboat installations are only good for twelve years. Replacement also depends upon how the boat has been used (or misused). Boats that have been repeatedly run aground are likely to have more keelbolt issues. Boats that have had bilgewater sitting in them for long periods are more likely to have problems. especially if the bilgewater has been allowed to freeze repeatedly. The visible ends of the keelbolts - the threads and their nuts - do not necessarily indicate the condition of what's below the keelson and inside the keel itself, as noted above. If water has gotten into the keel/hull joint, or entered from the top through the bilge, who knows what sort of corrosion could have happened. Without pulling the bolts (not easy) there's no way to be sure. If the bolts look good and the keel doesnt' seem to be moving, there probably isnt much to worry about.
Yeah.... but what if they were installed on Friday the 13th? Or perhaps in a leap year.... there's just too much to consider, overall. Since they're so close to the man's foot taking the picture, he should just take an air impact wrench and remove them. problem solved:D or maybe just buy another boat without keel bolts.
1 - 7 of 7 Posts
