I found these helpful instructions on docking and undocking today:
Docking and Undocking - BoatSafe.com
It's inevitable that when conditions are at their worst, you'll have an audience. Prior planning and practice will not only keep you and your passengers safe and protect your boat, it will also help you avoid serious personal humiliation.
Undocking Plan
When the wind or current is pushing your boat away from the dock the procedure is simple.
1. Cast off lines and pull in fenders as the wind blows you away.
2. When clear and safely away from the dock and other boats, shift to forward and depart at idle speed.
3. Be careful to make sure you have been pushed safely away and that the stern will not hit the dock as you motor forward and turn. Remember: A boat does not steer like a car, it pivots on its axis.
If the wind or current is pushing your boat toward the dock you will have to do some extra planning.
1. Cast off all lines except an after bow spring line. This line will keep you from moving forward and allow the stern to pivot away from the dock. (see illustration)
2. You may want to use a fender forward to cushion the bow of the boat against the dock.
3. Turn the motor or rudder to the direction necessary to push the stern away from the dock.
4. Shift into forward at idle speed. Slowly, very slowly.
5. The stern will swing away from the dock. When it is clear of all obstacles and traffic, cast off the spring line and back away from the dock.
6. When you are safely away, shift to forward and idle away from the dock.
Once you are clear of the dock, stow lines and fenders so they will not be in the way or pose a tripping hazard. Be sure to control speed when leaving the dock and check for other boats, swimmers or other obstacles.
