For my A-level Engineering project I am addressing the problems in sailing that could be addressed through the use of smart design. Any responses would be amazing!
Now that would be slick!4) developing a variable speed winch that automatically and progressively (i.e. constant variable torque- CVT) changes mechanical advantage based on the load on the winch handle. (In other words, most sailors can crank with 20-30 lbs of force on the end of a winch handle on a continuous basis. Initially a 1:1 mechanical advantage would allow a lot of line to be cranked in quickly, but as the sheet loads increase the mechanical advantage would shift to a higher ratio so that allowing the person on the winch handle to operate at a constant sustainable speed and load. This is similar to the reason that 12 to 21 speed bicycles exist.)
I think yacht designers are already doing a pretty good job of improving ergonomics already. Our boat was designed in the early 2000's and is very comfortable and easy to sail short handed even compared to the previous generation let alone boats from the '80s. Subsequent models seem to be even more friendly to short handed sailing.1) developing more ergonomic deck plan layouts focused on the sail control lines needed for shorthanded sailing
2) developing durable line locks that do not slip and do not damage the covers of highly loaded, smaller diameter, modern high modulus control line.
3) reducing the frictional losses on blocks and winches.
... Without using chemicals that are bad for you or the gelcoat.Stripping old, accumulatedantifouling paintvarnish quickly and easily.
Let her ride up on the bow as you beat to weather on a windy wavy day. She will change her mind about the location of the cockpit.My wife thinks the cockpit should be in the front. And the sails should be called sheets, not the lines. City girl.
Design a right angle, reduction, gear box to provide the torque necessary to crank a winch with an inexpensive cordless drill as the driver.For my A-level Engineering project I am addressing the problems in sailing that could be addressed through the use of smart design. Any responses would be amazing!
Pretty sure that has been done.Design a right angle, reduction, gear box to provide the torque necessary to crank a winch with an inexpensive cordless drill as the driver.
Yes I agree that is something that hasn't evolved much.One item that needs improvement on most sailboats is the companionway. Hatch boards should have been abandoned decades ago. The companionway needs to have a decent door system that is simple to open, keeps weather out, converts to screens quickly and easily and is robust enough or can be quickly fortified to keep out a big wave coming over the stern.
Some large merchant ships have experimented with using kites to reduce fuel costs. Why not design a kite system for use on cruising sailboats? The system should be easier for cruisers to use than a spinnaker; kite-board kites should be adaptable; attaching the kite with a Pardey sea-anchor bridle (one end attached to an anchor windless or bow cleat and the other attached to a midship cleat) should allow the kite to pull the boat at a closer reaching angle than a spinnaker (kite-boards can sail upwind); because the kite flies higher than the boats mast it should be in stronger/steadier winds than normal sails; etc. Who knows, perhaps if the system could be perfected enough it would do away with the need for a mast, standing rigging, etc. I have seen a YouTube video of a dinghy being sailed with a kite and it looks great. Also, kites used by merchant ships are self launching and tending so perhaps some of those features could be incorporated. If you make millions with this idea send me some spare change, I could use it. Or if you need a test bed I volunteer myself and my 50 year old 30 ft boat.For my A-level Engineering project I am addressing the problems in sailing that could be addressed through the use of smart design. Any responses would be amazing!
