Has anyone replaced the dome light bulbs (dual bulb configuration) with LED's? The only conversion kits I've found (Dr. LED) have one large LED array and a base connector as opposed to pins.
The solution I've come up with is to slightly bend the tabs which hold the ceramic bases in the dome outward from each other and use side pin configured G4 LED bulbs; otherwise the G4 bulbs would overlap each other.
Thoughts?
Thoughts?
