It is recommended that a class T fuse should be used because of the potentially high discharge current.
It is recommended that a class T fuse should be used because of the potentially high discharge current.I was thinking of using this on my LifePo batteries. Anbody see a problem? View attachment 145415
A lot of features for the price, bluetooth and cold temp shut down. Considering the reviews on Amazon I'm a bit skeptical of the cell quality BUT the company did respond with replacements. Maybe someone can jump in on why advance warning of BMS disconnect is needed.In post 1 I posted a drop in battery I found on Amazon (https://www.amazon.com/ECI-Power-Re...fos.765d4786-5719-48b9-b588-eab9385652d5&th=1).
The 2- 200aH ones didn't space fit as well as as 4-100aH ones. I watched some tear apart tests of both and they pretty much appear to be the same. I think I may even have gotten confused by the end and didn't really order the one I met too. I was going to order the ones that had a GA warehouse that I thought might be a fast delivery time for my in FL as they are shipping to daughter's house in Jacksonville and I am in West Palm Beach and have to drive up to get and hoped to do on the Christmas trip up.What changed your mind about the ones in your previous link?
Mark
Not sure I follow your statement <branch circuit fuses> since those are specifically designed for battery mount. When I switch to Lithium I will have to rework my battery bank(s). Are you suggesting one of those on each battery, then a T-type somewhere on the main lead from the bank, or just drop the MRBF ? I have read that a fuse on/near each battery is recommended in case of BMS failure or meltdown.No, those are common fuses used in LFP systems. The main fuse to the battery would be better to be a class-T fuse for interrupt current rating. Otherwise, those MRBF fuses are great branch circuit fuses.
Mark
Those can work as a main fuse, but they only go to 300A and some installations need higher. It is better to use a classT fuse for the main fuse right off the battery, as that has a higher interrupt rating, but that rating for MRBF is fine. Something like a MEGA fuse would not be appropriate as a main fuse. I use those MRBF's on buss bars after a classT to branch circuits for some things. You don't want a bunch of them on the batteries themselves going to branch circuits, however.Not sure I follow your statement <branch circuit fuses> since those are specifically designed for battery mount. When I switch to Lithium I will have to rework my battery bank(s). Are you suggesting one of those on each battery, then a T-type somewhere on the main lead from the bank, or just drop the MRBF ? I have read that a fuse on/near each battery is recommended in case of BMS failure or meltdown.
