1 - 15 of 15 Posts
I'm cruising from Florida to NY, one hop, no refridgeration. I'm bringing meat and dairy in the ice box. I can get block ice and dry ice nearby. I plan to use both. How much dry ice can I add without freezing everything? Any experience with this?
If you are using dry ice, watch out for the CO2 that is released as a gas. Your ice box probably drains to your bilge and the CO2 will will drain there as well (heavier than air) and has the potential to force ALL of the oxygen out of your cabin thus incapacitating you or at worst killing you.
I would just use block ice. You should get a decent amount of time out of it. You could also use the UHT pasteurized milk that can live on the shelf until opened. Freeze some of your meat solid and then thaw on the way. It would also keep your other contents cold.
I have been experimenting with both block,cubed and dry ice in my 5ish cubic foot icebox. The top is not insulated very well but the sides are. I have not had any trouble with stuff freezing unless it is right by the dry ice. Have not had any trouble with the CO2 produced either even with the boat closed up. One thing I will note is that you do not want to stick your head too far into the icebox or breath into it with the top off. The CO2 is pretty strong and I am sure you will note the same thing if you try it. :)
I found that 2 blocks of dry ice of around 9ish pounds would last a bit over 3 days. Each block is about a foot square and 3 inches thick. You can quickly chill a beer by putting it on the dry ice for about 45 minutes. :) If you forget it it will freeze solid.
I liked the dry ice better than block ice because my icebox drains into the bilge. I put a plug in the hole and just empty it in the morning to help hold some of the cold in. But spending $200 a month on dry ice has me looking at converting the icebox to a fridge. Dry ice is $1.29/pound where block ice is much cheaper.
I put the dry ice on some of those blue freezer packs that were pre frozen so if the dry ice all sublimates I still have some cooling in there. Once the dry ice is gone the temp starts to rise pretty quick without some mass to keep it cooler. Right now I am buying a couple of blocks of ice and an occasional block of dry ice. Blocks do last a LOT longer than cubes and stack more efficiently as well.
Old as Dirt!
FWIW I found that making a double layer pad of Reflectix (See Reflectix 24 In. x 25 Ft. Staple Tab Insulation - ST24025 at The Home Depot ), to fit on top of foodstuffs in our icebox, dramatically improved the longevity of block ice. While we now have a refrigeration system, we still use Reflectix pads in both the refer and freezer and our energy usage is reduced measurably. The material is inexpensive, easily cut and layers can be glued together with spray adhesive.
s/v HyLyte
Discussion Starter · #5 ·
Thank you all. I'm not too worried about co2, it's a small amount of dry ice, a large volume of well ventilated space. My thought is to use dry ice combined with block ice to extend the life of the blocks. I don't live aboard, so this will be a rare expense, just for this delivery. I'll look into the reflectix.
Glad I found Sailnet
I found this site
Reflectix Product Summary
which had these details:
Product Name: Reflectix
Insulation Classification: Radiant heat reflector
Thickness As Tested: .28"
Claimed "R" Value: 8.3 to 14.3 depending on type of installation.
Actual "R" Value (at product thickness): .67
Equivalent "R" Value (per inch): 2.38
We just bought big blocks and wrapped it in newspaper. We tore holes in the newspaper to allow more cold air to come out. We always had problems with stuff near it freezing. I never perfected it.
How long will it last?? No way to tell as we do not know how much insulation you have in fridge, how often you open it, how tight it is, etc. All this stuff about CO2 seems way over blown to me. I have used it so many times I cannot say. And let's face it - no boat is tight. Crap, most of us can't even keep them from leaking water in - much less keep air in!!!
I say use the paper. I seriously doubt it will be as good as the product mentioned above - but it is a lot easier and cheaper and by tearing the holes in it, you can adjust the temp. Tightly wrapped, with little access to the fridge, we might get 5 -7 days out of it (of course, I have kids and it makes that really cool fog in water!!!!). We used top buy it at Walmart and then at some grocery stores... but many do not carry it anymore. After that, you are down to "water"-ice, which melts. Another way to minimize your cold air loss is to make sure the fridge is packed tightly (every air space). Some people even carry plastic bags of those foam peanuts and shove them in the empty spaces as they can. We used to cover the top of the fridge with a solar blanket (cheap) so that when opening you do not let out all the cold air.
Hope that helps.
- CD
Discussion Starter · #9 ·
It worked. We put 14 blocks of ice on three cakes of dry ice. We put in three fresh and three frozen meats, two and a half gallons of milk, six dozen eggs, cheese, butter, vegetables. Because the trip had breaks, we added cubes twice, but also soda and more fresh food. Twelve days later we finally added more blocks (only four). Today, sixteen days after our start, I took out three peices of the original ice. The cooler is five and half cubic feet.
Many have died from breathing it in while unloading veg/fruit trailers.
CO2 residual gas is nothing to fool with.
Here's a freak, but true story, 1746 people killed in one night from CO2.
snopes.com: Carbon Dioxide Deaths
Travelling with dry ice on a boat or camping is safe in my opinion. You are talking about very small amounts of C02. The differences between a boat and a mine which has no ventillation, and a lake releasing 100 million cubic meters of gas are too far off base to even discuss.
Captains - if you do not feel safe carrying dry ice, fine. It is your boat. Do what you want and what makes you feel comfortable. But I have done it, I have done it with my kids, my parents have done it, and all kinds of other people have done it. I feel it is safe and pay no more attention to it than I would someone relasing methane in the head (hopefully).
- CD
W.Star, every boat is different, every icebox is different. Bear in mind that it can take 24 hours for the box to cool down, so you want to load it up with ice (whichever kind) a day or two in advance. If possible, stock it up at least 24 hours in advance and then add more ice before casting off.
I've never heard someone complain "we had too much ice" but I have thrown out spoiled food from not having enough.
Dry ice is great stuff, if you have a small igloo cooler or even a white styrofoam cooler you can always take some out if the box has gotten too cold. Or wrap it in towels or insulation to tone it down. And as has been mentioned--make sure it doesn't ventilate into the cabin, if the cabin is not well vented to being with. Unlike CO2, CO won't just up and kill you in your sleep, it will give you enough discomforts to get you up and out of there--but you still don't need that bother if you can avoid it. And of course, again unlike CO, once you get to fresh air you're out of trouble, there is no CO2 buildup in the blood to block oxygen getting back in.
Uhh.... Hello... he has already made the trip and reported back - inspite of the Dry Ice!!!!
- CD
Discussion Starter · #14 ·
Laughing...great reply CD.
HelloSailor, I do appreciate your input. My experience was that I fit three small peices of dry ice under fourteen blocks of wet ice. The three packs of frozen meat went aft near the dry ice. The two and half gallons of milk, four packs of fresh meat, five pounds of cold cuts, six dozen eggs, butter, sour cream, cheese and vegetables were happy at the other end. I added cubes twice because I could.Soda and leftovers too. Four more blocks went in on day 13. Parts of three origal blocks were in the bottom fifteen days after I sailed. I had precooled the 5.5 cu.ft box with cubes.
Yea, I don't think the small amount of dry ice will kill anyone. According to this dry ice website, all of your open beverages will become carbonated... be aware of that. The other thing I would recommend is that you do not put anything right next to the dry ice. The dry ice is -109°F. It will freeze anything next to it.
1 - 15 of 15 Posts
