1 - 4 of 4 Posts
Hi
My rudder has become harder to turn - the steering wheel has to be forced around. I suspect that crustations have wormed their way up into the bottom rudder bearing. When looking through the owners manual it mentions that the bearings are self adjustable but gives no further details of what they are and you can not see from the diagram that accompanies it.
Anyone had to drop their rudder to clean out, lubricate or replace one of these bearings. We are currently in the caribbean and I would like to avoid lifting the boat out if at all possible.
Could it be something else?
So far I have disconnected the steering rod from the rudder and then the wheel turns fine. I have also disconnected the autopilot (ST 5000) - they do not seem to be the problem which leads me to think that something is wrong with the bottom bearing just above where the rudder stops (and the shaft goes into the boat)
Any thoughts and advice on tackling the problem - the steering is slightly stiff but by no means seized.
Hi
Did u find out what the problem was. I have the same issue and the boat is currently lifted in Gib but due to go back in after tomorrow.
Would greatly appreciate any info asap.
Cheers
Mike
Hi
Hi
I had the same problem on my 34e performance based in Portsmouth Harbour, UK. In the end, I had it dropped when it was out of the water about 3 or 4 years ago, All the crustaceans were cleaned off and all the area greased, but the advice was that the way the rudder assembly was made up , it was likely to happen again. At that time, is was so light you could steer with your little finger ! 3 or 4 years on and its back to stiffness. I did notice that it eased up when in some challenging seas and using the rudder a lot.
1 - 4 of 4 Posts
