(As one involved high angle mountain rescue and who once did a lot of dynamic structural engineering) I disagree with MOST of what has been previously posted !!!!!!!
If youve ever watched (or did) bungee jumping .... ask yourself which type of 'line' would you use (and all at the same common tensile strengths, etc.)? .... Twisted stainless steel, a polymer equivalent of 'wire', dacron, nylon or rubber filled nylon (bungee)?
Why am I asking this question, as one who would NEVER use stainless or a high strength/low stretch polymer? .... and for 'engineering safety' reasons when impacting human bodies are involved???
Two very very very important reasons:
• IMPACT and its time interval of that impact which can be an exponential force MULTIPLIER
• Good old 'Archimedes' (and Aristarchus, the 'father' of trigonometry) - "levers".
1. Dynamic developed Force is MULTIPLIED in relation of HOW LONG/SHORT IS THAT IMPACT INTERVAL. The shorter the impact time the higher the developed force. Why bungee jumpers are relatively safe is because the 'stretchy-ness' also stretches out that impact TIME interval and as such VASTLY lessens the shock load due impact, that shock load being 'magnitudes' greater than the weight/mass that is 'stopping' due to the impact ..... and possibly the strength of the 'connections' and the gear.
Simple speak: if you use low stretch line/wire for your deck-run jack line runners the impact 'may' cause the CONNECTIONS to which that jackline is connected to see 5 or 10 or more TIMES the force generated by that weight/mass against that line if that line had a bit slack that allowed a noticeable (10+°) angle to form during full load. The 'longer' that impact interval becomes the less IMPACT there will be; hence 'safer' using nylon, as less impact forces are generated. If the impact forces exceeds the ultimate strength (at 5 or 10 or more times than inherent strength of the gear .... guess what happens? Ans.: MOB drill
"Stretchy" / elastic line (such as nylon tubular webbing or braided nylon line) greatly extends the impact TIME and thus reduces the impact LOAD.
2. One of the FIRST things any engineer involved in a static or dynamic structures course of instruction is "& beat about the head and face" is: #1 ---- NEVER EVER EVER design a structure that "divides by the sin (sin = trigonometric function) of the angle, especially when the deflection angle is a very 'small angle'. The reason is that calculation of the resultant forces generated by 'small angles' of deflection (applied perpendicularly) can be develop VERY LARGE forces, including 'infinity' in the item that is perpendicular .... such as a jackline. The smaller the deflection angle under load, the GREATER the forces generated at ~90° to the applied force (ie. moving body going towards overboard). This would be a parallel example of Archimedes being able to lift the weight of the entire world ... if he only had a lever that was large enough.
The exact SAME analogy apples to 'rope, etc.' that is stretched between two 'immovable' points; and then, force is applied perpendicularly to the long axis of the rope ---- can possibly generate INFINITE forces along the long axis of that rope.
Mountain and Rescue climbers would NEVER EVER EVER EVER stretch a TIGHT line horizontally across two 'mountains', peaks, crevasses, open spaces and apply a 'hanging' load at perpendicular to the axis of the rope. To do so, which would prevent any 'sag' (thus generating 'small' angles of sag) in the rope --- aka: dividing by the sin of the deflection angle) and would generate (the possibility) of infinite forces in the 'rope' or the connections, or the rock, other gear, etc that 'connections' are affixed. Any time such a 'Tyrollean Traverse' (horizontal line with a hanging perpendicular load) between two fixed object the rope is ALWAYS set to that it has 'lots of sag' (larger trigonometric angles by which to divide into that load, the larger the 'angles' the less the load into the terminal connection of the rope AND the rope itself).
Calculated Trigonometry Examples ( one horizontal rope between two immovable connections and a 200lb. person hanging from the middle of the horizontal rope and pulling on the rope 'perpendicularly')
Calculation Formula: weight ÷ sin (sag angle) = resultant force
'sag' angle Resultant force (by 200 lb. person)
30° 400 lb. (force)
20° 584 lb. (force)
10° 1151 lb. (force)
5° 2194 lb. (force)
2° 5730 lb. (force)
1° 11460 lb. (force)
0° 'infinite' (force)
....... and these are only 'static' forces without impact.
For (guestimate) impact MULTIPLY those resultant forces by 5X.
With a gorilla tight jackline of stainless steel or amsteel that 200lb. body with 5X added (guess)magnification force IMPACT factor could 'theoretically' approach 60,000 lb.(!!!!!!) into that TIGHT (1° deflection) line AND its connections to the boat! ...... But only 6,000 if that deflection angle is 10°. Even LESS for larger deflection angles at full impact load.
Rx: SLACK jacklines and 'short' tethers and 'stretchy rope/webbing'.
1. Use 'stretchy' line for jacklines and DO NOT use low stretch materials such as wire rope, dyneema, etc. - otherwise you risk pulling the jackline connection OUT of the boat during FULL high impact scenarios. Reason: With non-stretch - higher impact values and LESS deflection angle (dividing by a very small number).
2. Do NOT pull the jackline to 'real taught', leave 'some slack' so that a relatively large angle is formed between your tether connection and the line when the weight of the falling body is 'at the end of his her rope' - otherwise you risk pulling the jackline connection OUT of the boat during FULL high impact scenarios. Reason: LARGER deflection angle (dividing by a very larger number yields smaller results/forces).
This will prevent breaking the cleats and other fasteners to the Boat 'off' the boat, will vastly increase the impact time; hence DECREASE the impact (total load induced).
Do 'proof load' your tether and jacklines ..... example: with your harness on, your tether attached to the jackline and to your harness ...... start from the centerline of your boat, "run like hell" towards an open lifeline gate ....
1. see if you are kept reasonably on board with the now at full extension & tight tether/harness. If now overboard, shorten your tether, and then repeat. but go faster across next time.
2. make sure the 'connections' from the boat TO the jackline are still intact - not bent, pulled out, deformed, etc. etc. If so, make 'stronger', much stronger (includes 'cleats')
3. have an assistant estimate the angle that the rope (from the tether connection to one of the boat connections) makes with your centerline .... should be 10-12° or more. If less than 10-12° shorten the tether and slightly loosen/lengthen the jackline.
If you want to proof load 'less dynamically' get three to four buddies and all of you - stand near the rail and try to force yourself over the side ... everyone pushing 'hard' against that jackline system.
hope this helps .... helps you to stay onboard.
Slightly SLACK jacklines made of tubular ('slightly' stretchy mountain climbing grade) webbing & short tethers are to be preferred; in comparison, ............... to being 'accompanied' overboard by silly looking broken fiberglass boat fragments firmly attached to broken tether/wire or amsteel rope/jackline terminal connectors, etc.
My tubular webbing jacklines run 'mostly' along the centerline of the boat.
Anyone ever see someone using a stainless wire rope or dyneema 'bungee cord'? .... now you know why you haven't. ;-)
