I have failed to repair my fiberglass.
between the black and fresh tanks in my bilge is a fiberglass wall. The seal broke at the top of the wall, letting fresh water flood into the black tank. How may I seal this?
The issue is the inspection hole is 2' from the wall that needs repaired, and my first blind repair attempt looked like this:
I can confirm I just tested it, and it does not work.
My next thought is to drill a few 2" holes along the top where the two meet up, and work thru those small holes to patch it much better.
I am wide open to suggestions on this one. The first idea I had failed, and the second may fail as well, or worse, cause damage.
