Hey all! I just recently purchased a 1975 Venture of Newport 23'. I've been out about 5 times and have had the main sail up three times.
Today we were sailing with the wind at a 45 degree angle. The main sail was out port side, keel down, and we were cruising nicely for about an hour. All of a sudden the wind started hitting blowing directly port side pretty hard and the boat started to tilt heavily port side.
THIS IS conflicting info...if the main is to port you are on stbd tack first of all, you say the wind is hitting PORT side meaning its coming from the opposite side or do you simply mean you got a stronger gust from the same side making you heel to port more or leeward? if so you simply got overwpowered, thats an easy fix.
I tried to turn us directly downwind to take some power out of the sail while and told my friend to pull down the main. She couldn't pull it down so I left the rudder and yanked the main down.
this is a classic mistake you actually made the main face the wind more in essence POWERING UP especially in a gust(a lot of dinghy racers use this with wind shifts to gain speed and surf, you can see it when rounding bouys on a dowwind leg
correct procedure there is depower main and or head into wind
As soon as I left the rudder the boat tilted hard and everything crashed around in the hull. I pulled the main down and ended up tearing the top of it. Which I'll post in a different thread.
never ever leave the rudder
What did I do wrong? When you feel the boat leaning too much leeward how do you correct it to prevent a capsize?
you did a couple things technically wrong, first dont power up by having the main or sails face the wind more, especially in a gust
you did not depower enough that means for the first times completely releasing mainsheet, depowering equals not heeling over too much and capsizing...simple.
Thanks!
THE ONE thing nobody is really mentioning in all the good posts is YOU LEFT THE HELM you had crew, crew drops sails...
of course if you are downwind or the main is fully out thats hard to do so the thoughts on heading into wind are right.
on small boats no matter who you think you are or how good you are you cant leave the helm without it either rounding up or down.
YOU NEVER LEAVE THE TILLER.
this is what caused the "crash"
I always tell new dinghy sailors and small boat sailors that are learning is that
the mainsheet is the clutch
to depower before thinking about shifting gears(sails, and reefs) changing lanes, turning etc(I use these analogies cause it helps people understand in common terms) you release the mainsheet or push down the lucth pedal
this will imediately on most small boats and all dinghies depower you drastically to the point many fall back into the windward side and wet their butts
your on a bigger 23 footer but this is the only way to control heel and avoid heeling so much you gybe or round up and tack over unintentionally.
sooooo for new sailors
mainsheet is CLUTCH
main sail is 1st-3rd gears(power gears)
jib is 4th and 5th gear or override
hope this helps
btw you did nothing wrong...learning to sail is doing this many times
you will learn to feather the mainsheet out gradually and keep speed...
same with rudder you will learn when you have to much weather helm and learn when you need to either reef or depower main etc...
also remember that your jib is the second rudder if you will, it has to be trimmed correctly in all wind angles for you to have correct rudder feel and action.
cheers
ps. the crash you say(i edited my post) sound like you eventually gybed since you went downwind...you probably got behind the wind and the main "crashed" over...
one rule you should always heed to is:
dont back wind the main
you cant lower the main downwind(not true in some cases but just remember that the main should always be lowered or reefed into the wind, prefferably with some forward movement as it will help)
hope this helps a bit...and keep trying, practice makes perfect!
