So I have this sketchy precision 15k boat.. I think it’s together enough to work with just the mainsail after replacing some stuff.. I think I have it’s rigging figured out right..
Will have a small outboard on it..
So here is the plan..
Launch it if I can back in deep enough with my WRX.. May bring provisions for launching it with a strap, or trying to, if I can’t back up far enough..
Park car and whatnot..
Motor the boat out to the middle of the lake..
Raise motor? (Or keep it handy? Idling?)
Point front at wind..
Raise the main sail leaving the main sheet pretty loose.. (no reefing eyes)
Pick a direction about 45 degrees into the wind to aim..
Control rudder with right hand and main sheet with left..
Pull tension on main sheet, slowly, which should power the sail..
Boat should move..
Get the feel for it and figure out what it does..
How to stop if I get into trouble or get out of control..
Loosen the main sheet to depower the sail..
Try not to point directly into the wind and tack, or away from the wind and switch sides, or the boom will swing and try to kill me..
If the wind gets really crazy pull the main sail all the way down and wrap it up..
I’ve never set foot on a floating sailboat before, I don’t recall..
I don’t know anyone who knows how to sail..
I’ve read a lot but I just don’t think I’m going to “get it” until I just do it..
I think when I can feel what it does I can figure it out, and it will probably magically all make sense..
Should I take my girlfriend and endanger her too? Or should I risk my life alone?
Really, I’ve never even piloted a boat with a gas engine before..
Sound like a good plan?
Edit: Almost forgot to ask..
If I fall off the boat what is it going to do?
Is it just going to keep going across the lake without me?
Boat should move..
