1 - 14 of 14 Posts
okay, i still need a real dinghy, and having a 27 foot boat a porta boat looks like a great idea, but they are pricey, very pricey. i found a plan on line for a folding dinghy that uses marine canvas ( would be sunbrella and replaceable if possible ) for the hinge and transom water proofing. the real problem i see with it is it uses 3/8 ply and weighs 80 lbs for a 10 footer. i wonder if using 1/4 ply with a layer of glass inside and out would be strong enough, and weight less, and shrink it slightly to around 8'. i am thinking a layer of 6 oz inside and out, which would weight roughly a pound per square yard, and the boat probably is around 6 or 7 square yards. so if it weights 10 lbs with glass and epoxy, but weights 20 lbs less than 3/8 ply would it be stiff enough. i would be happier with the final weight around 60 lbs, and by shrinking it i might be able to get more than one section out of a sheet
what does every body think of the strength of 1/4 ply with 6 oz glass? i would mod the plans some by putting in porta boat style transom, which folds with the boat then a second removable layer of wood to make it solid.
one thing i like is the plans i found look better than a porta boat too
IF you posted a link to the plans, it would make it easier for us to advise you. :)
Personally, I like my porta-bote... but it was originally not bought for use a sailboat tender, but as a fishing boat...a gift from my wife. :) That may be biasing my opinion a bit... but it rows credibly well and motors even better. :)
There's an existing design for an 8' folding dinghy called "Flapdoodle". The designer has a website. he claims it's light enough to carry under your arm. There's also a building blog about one of these called "barquito". Have fun.
For the Flapdoodle.. see HERE
One of None
Hunter 34
Ply with glass and epoxy would too heavy. most plywood designs do not need glass. Consider a nesting dinghy like the spindrift instead.
Discussion Starter · #7 ·
this is the one i found boat plans
i will look in the other posted here, thanks for the links
as for a nesting my wife already has to stand when at the helm because cant see over the cabin, so a nesting one on the deck is out of the question
Why not get a used Portabote? I did from a member here at Sailnet and we are quite happy with it and used it last weekend with the 2 HP Honda, having, as my son noted, "four and a half knots of fun" and using about six quarters' worth of gasoline.
Discussion Starter · #13 ·
well this research will take a while to see what i want. i do like the look of the pointy bow, but i do understand the storage issues.
i also need research material costs, because i can get an used inflatable for 300 to 400 that will do what i need, but i still like the storage of a folder with out deflating and reinflating.
I bought the plans for the origami 8 from here:
http: // www. woodenwidget. com
I haven't yet built mine, but it looks easy enough, the plans are good value for money, very detailed. (Disclaimer, my only association with this company is as a customer. I will not make any money if you buy their plans)
Dave.
1 - 14 of 14 Posts
