1 - 14 of 14 Posts
I have just finished figuring out the patterns for foredeck and cocckipt awnings for a winter project. I was about to head for Fabricland (local fabric retailler) to get some rip-stop nylon in the morning when I stopped to look around the sailrite website. I caught a forum posting about NOT using ripstop nylon for this purpose.
Does anyone have a better solution? I am trying to make a set LIGHTWEIGHT awnings. Not something to sail the boat with.
Discussion Starter · #4 ·
My thought was to put 1" nylon webbing down the centre seam and along the edges. These will have web loops holding 1" rings in place for the lashings. I find it hard to believe that ripstop nylon will deteriorate that quickly. It's the same basic material as used in the construction of the upper portions of a tent.
I think it depends on how much UV it gets. Nylon tents don't actually hold up all that well when left set-up continuously in intense sun. I think that's why you see so many long-term camp-tents made out of other material.
You're up in Canada (yes?), so maybe the sun is not so intense up there and you may not use your awnings quite so much either. Maybe the nylon would be fine.
Think about the circumstance when you would use the awnings. It needs to be reasonably strong, because eventually you'll leave it up while you go ashore, the wind will pipe up unexpectedly, and it will take a beating in your absence.
Sunbrella is expensive but very durable and provides good shade. I think a lot more UV gets through nylon.
I'd agree that ripstop is not the best awning material.. but for a lightweight sunshade regular sunbrella might be a bit heavy. The [problem with a nylon awning is that it will have a lot of stretch and little stability in any kind of breeze.
Down in the Caribbean our friends use a material that resembled Sunbrella but was about half the weight.. sorry I don't know the tradename of the stuff but something like that is available I'm sure (they had theirs made by a sailmaker in Guadaloupe)
Good tents have polyester flys because it resists UV better. Canvas, if dried properly lasts a real long time as evidenced by out troop's tents that are 30 years old and still working. To me though, if your leaving them up for months that's one thing. I have to bet that your probably not and the nylon will most likely last a number of years.
My awnings were made using sunbrella. It is heavy, but I know it's gonna hold up, and it doesn't flog around in the wind nearly as much. If you sew pockets onto it, and cut PVC pipe to slide into the pockets, it will stabalize it even more and keep the edges a little higher off the deck, making it a little easier to get on and off the boat if your at the dock.
Too true, SST
Any awning, esp one in a windy area, is going to need some sort of stabilizing battens or poles to stay in place.. it also maximizes headroom beneath the awning out towards the deck edges.
Discussion Starter · #10 ·
I get the point about some sort of stiffener for the cockpit awning. I'll redo my plan for that one.
For the foredeck awning I am planning to curve the longer side upwards to help avoid flogging. The current plan is a smooth curve with the furthest point about 4" above a straight line drawn between the aft connection and the forward connection. All the outer edges will be reinforced with 1" nylon webbing which also allows me to attach 1" rings for the rigging.
Don't sweat the sun damage for awnings. If you're sewing it yourself which is a snap, just use polyester with nylon webbing for strength and call it good. All this talk about UV damage is just hype. The way this discussion is going, I'm afraid to go out in the sun wearing my nylon flats-fishing shirts. They might decompose right off my back!! Ha!!
Good luck and take all advice with a grain of salt (including this!),
Pat,
Rip stop will work fine if using it on a calm sunny day. I made mine out of white as it does not absorb the heat as much as color. It still lets light light through and offers plenty of protection from the sun.
I also made one out of sumbrella. Used for days of heavier wind and scattered showers. If you spend a lot of time anchored out I think you will find uses for both.
I would also suggest as STT recommended using PVC to make support battens for the sumbrella. I used 3 foot lengths with screw connectors to break them down. Use 3/4 inch for the Sumbrella for strength.
I sued collapsible tent poles for the rip stop nylon. You can also get creative by adding zippers to attach side curtains around the cockpit for heavy rains and netting at night for bugs.
Good luck, it' a fun project
Be aware that if you're looking to have the awnings for UV/sun protection, ripstop nylon, especially once it gets wet, provides very little in the way of UV blocking. IMHO, you'll be much better off making the awnings of heavier UV-resistant material, as you'll have far longer between repairs or replacement.
Discussion Starter · #14 ·
It isn't so much for UV protection as it is to just as a shade and to block any random raindrops or dew from entering the usually open hatch above the v-berth. I am replacing the v-berth cushions for the simple fact that they have serious water stains and a little mildew. The build cost on the foredeck shade so far is a whopping CDN$29 (or US$23). Even if I have to make a new one, I'll be able to use this as a pattern. The basic idea comes from this top at Defender
1 - 14 of 14 Posts
