Hello all:
I have a fairly tender Cape George 36 which sails well in light airs, but was not factory finished and is a bit underballasted. The previous owner reported 3000 lbs of lead was put in the boat, the rest finished with concrete.
I've spoken to the builder/designer... Cecil Lange and he told me the boat probably needs 2000-3000 lbs of lead to sink her down to her proper waterline.
The plan is to go offshore in about 26 months, and with that will come quite a bit of extra gear... mostly where I won't want it (on the ends of the boat and on deck).
Has anyone added ballast to their boat, or have any knowledge?
I had two plans concerning this... the first was to try more ballast in the bilge where possible... maybe with up to 1000 lbs.
the second plan was to form a lead shoe of 1500-2500 lbs (whatever we decide was necessary with all the additional cruising gear we'll be taking) and mold a shoe that would get attached with polysulphide or epoxy and then glassed over and laminated to the bottom of the keel.
A lot of questions come up:
Forming and molding the shape...
I was thinking about buying lead from tire stores around... and getting their used tire weights... anyone know other good sources for lead?
What's the best way to form lead? A tiger torch? Has anyone used something as a cast... if so, what? How could I build my own cast... for pigs or for forming a shoe?
Concerning the second plan--the one about the shoe:
I didn't want to pierce the encapsulated keel with bolts (that would be my reason for laminating), so does epoxy bond to lead as well as it bonds to wood or glass, if I prepped the surface adequately? My ship right friend was suggesting 5200 or polysulphide, and jacking the lead to the bottom of the keel in a few or several pieces, which would hold the lead in place until I could get fiberglass around it and to the keel. I really like the shape of the keel and the boat sails so well for a full keeled vessel... i just wanted to increase the draft by 4-6 inches or so (whatever was needed for the job), because the formed shoe would be about 5 inches wide.
Any words of wisdom, accounts or stories, or resources to point me in the right direction?
Thanks folks,
Tom
Thanks folks,
Tom
