- Reaction score
- 25
All right, so this might be a silly question, but . . . we have a new boat (2001 Catalina 320). It has an inboard diesel - this is new to us. Up to now, our sailing experience has been with in an outboard mounted off the stern.
In that case, we would simply raise the outboard out of the water when sailing. Simply: no drag, no wear & tear on the motor.
On this new boat, however, what do we do with the transmission when the motor is off and we're sailing? So far, we've been leaving it in Neutral. Interestingly, I can see the prop shaft turning as we're underway. Does this cause any "non-good" wear in the transmission.
Other people have told me that you should leave it in gear so that the prop doesn't rotate.
Opinions? Thoughts?
BTW, it's a Catalina 320, Yanmar 3gm30 diesel engine, 2-blade fixed prop.
Thank you!
Opinions? Thoughts?
Thank you!
