hi folks. i have scheduled for my rig inspection and tune and i will be measuing the actual measurements for the fore and aft triangles. so, now is the time for sincere thought about sails.
i am considering running her as a sloop with a 100% jib; maybe set up as self tending.
i have also considered setting it up as a cutter with a 90% forestaysail and the smaller jib. the boat was designed and set up with the cutter option as a possibility. one thought about that is it has a lot of rig flexibility in different conditions. i could also set the ( smaller ) jib up as self tending. i like this option but then i'd probably have to use running stays and simpler is better.
i haven't decided yet about headsails. i will discuss these options with my rigger and, of course, the sails that the marina has ( which i can look through and choose what i want ) will have some bearing on what i do.
but my real question for this thread is about full battens in mainsails.
they are good for performance and i hear they reef well. this boat would not have had full batten mains and you usually only see multihulls using them but, i think it might be a good consideration. i have no intention of racing. i will be mostly cruising ( day sailing when i don't have time to go for more than an afternoon).
so, any thoughts about that option? one question is availability. i am thinking used catamaran sails. the only concern i have is the depth of the roach. i have a backstay and a lot of catamaran sails have a pretty deep roach. of course, i could use a sail with a slightly shorter luff but a deeper roach. for all around cruising a more moderate aspect sail is better, anyway. i think the original for this boat was fairly high aspect.
anyhow, if anyone has any input i'd be glad to hear it. thanks
ps. plus, catamaran sails are usually so colorful and pretty!
