1 - 7 of 7 Posts
Discussion Starter #1
Hello
I am fitting out my aluminium sailboat. The water tanks are built into the hull. I have tank tops from 5mm aluminium. M8 aluminium or 316l bolts to secure the top down.
What I need help with is wether to use a gasket tape of some type or just silicon the tops and bolt them down.
There are 4 tops. 2 separate sections. I have a 120mm vetus opening for each compartment and 3 x 38mm holes for in, out and vent.
Any suggestions?
Dennis
I’d use a gasket, if I could. If not available, or I couldn’t make one, or it just didn’t seal well enough, then I’d use a food safe sealant. The sealant would be effective, but make it much messier next time you wanted to clean your tank.
Try the McMaster Carr website for gaskets. You can search the site for materials that are NSF 61 or ANSI certified for potable water use, I believe.
Here’s a link to a list of sealants that have the NSF 61 certification: Listing Category Search Page | NSF International
Also found the list of NSF 61 certified gaskets.....Listing Category Search Page | NSF International
A google search for NSF 61 certified gasket material brings up several companies that sell what they say are compliant sheet materials, but I didn’t do any checking to see if any were actually on the NSF list.
Hello
Any suggestions?
Dennis
Gasket with spares. I would even see if you can find rubber/ neoprene o rings. It will help keep the pressure in the tank.
Those are the clean out tops I am assuming.
I imagine the Vetus openings are all he will ever need for cleaning. I'm thinking those tops won't come off for 20 years.
1 - 7 of 7 Posts
