1 - 14 of 14 Posts
Discussion Starter #1
Hi!
I am in the market for new/slightly used Genoa for my US Yacht 25. I took my trusty 30' tape measure and took measurements.
I'm getting confused with regard to the foot of the sail, and the J, and the LP.
Some websites with sails listed show only the sail's Luff and Foot. I guess I'm getting confused when it comes to the foot. Other sites show the Luff and L/P. What should I be looking for when a seller only lists the luff and foot.
Here's my measurements:
Headsail Luff: 26' 3" max.
LP: 11' 3"
J: 9' 7".
Goal is a 133% Genoa.
Thanks for any help!
Chris
Richland, Wa.
You really should look at the headsail area. You can calculate the area using Luff x LP/2 = Area. If they give you luff, leach and foot, you'll have to do a some geometry/trig calcs to get there. If they only give you the luff and foot, you will have to guess. The LP will be less than the foot, but it depends on how high the sail is cut. Looks like for your boat I=30.27' and J=9.5' so 100%=30.27x9.5/2=143.8 so 133% would be 191.2 square feet.
no longer reading SailNet
I'm looking for a smaller headsail now (leaning towards having a new one made) and find it useful to look at both sail area and LP. You can have 133% LP sails made to almost any sail area by varying the luff length of the sail. On a 133% it is unlikely that you'd make the luff length short, but on smaller sails (<100%) they are often cut that way.
I also find that doing a search on sailritesails.com will give you target dimensions for common sail sizes on your boat. Here is a link to your boat (the second genoa listed is about a 135%):
http://sailritesails.com/ShowAd.aspx?id=6486&sourceid=2
The sail for my boat that will be about 200sqft. A 200sqft sail for my boat (39' forestay, 37.5 I, 11.25 J) could be made as a sail with a roughly 32' luff and 14' foot (around 105%, called a working jib), or with a 36' luff and 11' foot (around 95%, called a blade jib). Both have the same sail area, the aspect ratio and LP are just different. The blade seems easier to tack.
Discussion Starter #6
Thanks to everyone for the great help! Much appreciated.
Chris
Richland, Wa.
BTW. For virtually all masthead rigs, when you do the trig, foot and LP are virtually the same.
If virtually means within 20%, then yes, you are correct. It depends on the angle of the foot to the luff and the angle of the forestay.
I check filter as a first gauge, but still do the actual LP calc to check percentage overlap. I also check square feet if the sail that I'm looking at doesn't use the full luff.
I must be using different trig then you. it would make the sail makers job a lot easier . all sails would be square. the LP and foot can never be the same on a triangle sail.
run a tape up your forestay attached to the halyard. That gives you a good idea of the luff length you can use. LP is easily determined by measuring shortest distance from the clew to the luff. Divide this by your boat's J measurement and you have LP.
Mike
Mike
and you will have percent of overlap
Discussion Starter #13
Great conversation. I learned a lot. Thanks, all!
I admit that on a short mast, the numbers don't hold quite as well, but assuming that my mast is fairly typical, the difference between LP and foot is maybe 5%. I did not mean imply that they were the same, only that they were close in many circumstances because the luff angle is rather large. The arithmetic follows. If I made a mistake somewhere, I'm not seeing it. :(
1 - 14 of 14 Posts
